1" Mandrel
1" Mandrel
1" Mandrel
W.C. Turner
>Hi all,
While I'm waiting for my neck to recooperate, I need to locate a supplier for a 1" hook and loop mandrel, for cleaning up the nib on the bottom of bowls. I've got 2", & 3" ones already. Where's the best place to get one?
Thanks,
W.C.
Email: Remove 2
Re: 1" Mandrel
Re: 1" Mandrel
Juergen
>Try this site
http://www.esva.net/~thesandingglove/
Re: 1" Mandrel
Re: 1" Mandrel *LINK*
Russell L. Babbitt Jr.
>Is this what you're after?
Craft Supply
Re: 1" Mandrel
Re: 1" Mandrel
W.C. Turner
>That's it. Thanks.
Re: 1" Mandrel
Re: 1" Mandrel
Gil Jones on Lake Seminole GA.g
>I suppose you could buy a new 1" sanding disk holder. In my case, I just cut down an old 2" holder to 1" after the sponge sheared apart for the 3rd time (I CA them back together). A good scissors will do the job. Wal Mart sells 2" Velcro strips that are 5 feet long, and work fine to resurface the holders. (Bar code # is 0 75967 90982 6). Clear CA works OK, but the black/flexible CA is better (and costs more). Yes, I am into saving money.
Re: 1" Mandrel
Re: 1" Mandrel for carving
>I love the 1" sanding discs for cleaning up carvings. I use them in my flex shaft. I had to buy a handle that would take 1/4" shank but it won't take the hex shanks so I have to make sure they are round.
Re: 1" Mandrel
Steve Worcester
>We sell them also. It isn't normally listed because we want you to understand that the 1" (30 mm for us) is a bit different to work with. Turn the lathe off and just use the pad and sandpaper to remove the imperfection. Works great for carvers to clean up detail also.
Steve Worcester
www.turningwood.com
Re: 1" Mandrel
>Steve I think I bought one of mine from you. I love it. I need more. I like to have one for every grit. It keeps the wear and tear down to a minimum. Let's see how much money I have left after the symposium. Yea right. maybe I'll get a good check from my gallery after I get back.
