Re: Mark- wait a minute,.... *LINK*
Mark Kauder, Phenix City, AL
>Jamie,
Sorry, I misspelled the guy's name: Sweazey
The descriptive flyer for the gouge is quoted here:
"Proudly made in the USA, The Sweazey 1/2 inch bowl gouge is produced from premium M42 cobalt high-speed steel. This steel was chosen because of its superior wear resistance and edge-holding qualities compared to the more common M2. The heat treating process is accomplished in a vacuum chamber (to prevent contamination) followed by quenching in nitrogen. The steel is then tempered at 1000� F in a nitrogen atmosphere to achieve a hardness of 66rc yielding a very hard (but not too hard) material. The result is an exceedingly durable edge able to retain its sharpness for a very long time.
Well-known Pacific Northwest Wood turner Dave Schweitzer provided valuable assistance in meeting several design objectives. Beam strength of the tool when extended well over the tool rest, the capacity to expel chips freely and the ability to work well with a wide variety of grinds were accomplished in this deep-fluted bowl gouge.
The unique handle is drilled 12 inches from the outboard end and filled with lead shot. This provides "heft" as well as vibration absorption to the tool.
The superior edge-holding steel, the advanced flute shape and the vibration absorbing handle all combine into a premium bowl gouge that should be a pleasure for any woodturner.
The tool is available handled for $84.00 or unhandled for $59.00 plus shipping and WA sales tax for Washington residents."
There are two grinds available. One is the conventional swept-back thumbnail grind. The other is a convex grind referred to as the "DS" grind for Dave Schweitzer who is a strong proponent of this style grind and contributed greatly to its design.
Two pictures are attached. The first shows the entire tool. The second shows the two grinds available.
I will be looking forward to hearing from you and thanks for your interest,
Bob Sweazey
21701 112th St. E.
Sumner, WA 98390
253-862-9643
http://www.sweazeytools.com/
