Feels Like Neck is Broke
W.C. Turner
>Hi all,
I'm up writing this now because I can't sleep. Or I should say, I could sleep, but, I can't find a position to lay that my neck don't hurt. Here's the story. My neck has been hurting the last couple of days for no apparent reason. But, at my age, a reasonalble explanation is not necessary. Anyway, today, SWMBO, says, maybe it's because you're doing more turning . I first said, No Way, but, the more I thought about it, I think maybe she's right, as bad as I hate to admit it. That's got to be what has caused this.
As I think about it, I believe I have seriously strained the ligaments in my neck. Very sore, from the base of the neck, all the way up into the skull. I was trying to finish a piece, & you know how you try to keep from tearing the end grain, or accidently hitting the piece with the tip of the gouge, or something else dumb, but, I surely wasn't aware that I had tensed up my neck muscles to this extent.
I can barely lift my head, can't turn head side to side, as in driving to look for traffic. Aside from having your lower back go out, this is the worse thing that can happen to you, I believe. When your back goes out you aren't able to do anything, and this falls pretty much into that category.
I was just wondering if anybody else has had their neck get sore like this from turning, and what did you do for it, short of suicide?
Thanks in advance!
W.C.
Re: Feels Like Neck is Broke
Rick in Colgate, Wi
>Hey W.C.,
Ever been to a chiropracter? Anyway, I used to have my lathe spindle at elbow height and was experiencing back and neck strain. So I raised up the lathe another 1.5" and it made all the difference in the world, I must of found the sweet spot for me physically.
I do visit a chiropracter on a regular basis for back and neck problems.
Re: Time to do some readjustment...
>As Rick said - consider adjusting the height of your lathe. Also, consider doing some excercises. Get a referral to a physical therapist from your physician. The PT will happily give you excercises and stretches to help you with your problem. I escaped rotator cuff surgery for a partial tear that way.
Mark Trenier
>Having a fused neck myself, I know how you feel. Do you wear a heavy face mask? That could contribute to your problem. See a doctor, and use some ice packs to keep down the swelling. 15 minutes on 15 minutes off. Just my 2 cents. Hope you feel better soon.
Mark Trenier
>Barry I would also guess lathe height. You can see if it's too high by simple standing on something. To check for too low is a little harder because you have to raise the lathe. I also have my lathe about 1" above elbow height.
It might also be fighting the tools. I used to wear myself out when turning and now I notice that my hands are much more relaxed and so is my body. lots of practice solves most of the problems ( but can cause elbow and wrist problems) Try concentrating on relaxing. doing curls and reverse curls helped my Tennis elbow and carpal tunnel. Now if you could just figure out a way to make it easier for me to get out of bed in the morning.
Dave Belser
>Good points in the posts above. Raise the lathe height if you can would be my bet. But also if you are anything like me, I find that there are times that I get so "into" what I've got on the lathe that time stands still... Problem is time dosn't and the reality is I've been turning in more or less one possition for several hours. To combat this I use something to remind me to take a break. If I'm listening to music, I stop working for a few minutes and move around at the end of each album.
- Dave
georgetroy
>This is what I posted on the AAW formum:
A pulled muscle in neck, back or elsewhere can result from swinging the golf club. For lathes I have found working on the end of the lathe reduces a neck ache. It takes the right kind of machine for this. I will get more aches from the spindle center being high. Yes I know this is argumentative, but I like my height same as the end of my elbow. I will get a muscle ache in the right arm when I have to keep the tools above my belly buttom. For golf (arthritis) I take a pain pill and keep swinging. Whee it loosens up. My ideal lathe height seems to be about 42-43" for approx. 5'9". I do not like the spindle center higher than that. Anyway as we age we all have different aches and pains, as if you didn't already know that. GT
Hello W.C.- I can help !
Ray Carson, New Jersey
>Sounds like your in a lot of pain. Sorry to hear that.
You need to lend me all your lathe tools since you'll be laid up for a while. :-)
I get that way sitting in front of a computer drafting for 10-12 a day. As others have said, finding a comfortable position to do repetitive work is key. I also get pains in the neck pain from looking at the monitor for too long, especially when I have a big project with a tight deadline. The tension builds in the muscles and you don't realize it until it gets you or you break to do something else. I also have soreness in my finger joints every night from typing. One hand on the mouse, the other on the keyboard.
Once you get better, and I hope you do, try adjusting your wood workiong habits, your equipment location/height.
Hope you feel better.
Brad Vietje
Stretching, Spindle Height, Eyesight, Rest Height
Brad Vietje
>Yup, Been there !
I agree with John and others that changing the spindle height and stretching can really help, as well as trying to be as relaxed as you can while turning. The first Christmas season that I decided to make lots of presents was pretty bad for me. I was making lots of small, intricate ornaments in an unheated garage, (and it was real cold that December), and I found that I was tense, and that my shoulder muscles were clenched from trying to turn pretty intensively for 6 - 8 hours per day in the cold. Sleeping was difficult and sometimes quite painful.
I ended up developing a softer grip on my tools, and stopping to stretch -- even hanging from the rafters for a few minutes or trying to stretch my shoulders down and back helped quite a bit. For now, you'll have to give things some time to heal before you can get too aggressive with your painful situation.
Don't overlook eyesight(HA!)and whatever eye protection you use. My vision is changing rapidly, and I found that I was working down close to the spindle to see the finer details (bad for back, too). I needed to raise the spindle as well as stand more upright to increase the distance between my eyes and the spindle, and got a faceshield and a pair of goggles that allowed me to see better without wearing my glasses. Now I need bi-focals, so the dymanics will be changing again.
Toolrest height: Many of us learn to turn with the rest way up in a spindle planing position, but not all tools work like a skew. With the rest up at or above center, I find turning spindle details almost painful -- causing my shoulders to be drawn up around my neck -- bad for my wrists, arms, back and neck. I have gone to a much lower toolrest position for most gouge work, cutting with the side of a steeply-angled longer bevel tool, and only use the higher position for certain skew cuts. This may not work (or even apply) for you, but it did help me.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Neck Pain
Thad
>Rest & Ice of course, but I would agree with the previously mentioned response to find a good Chiropractor if the pain does not subside. Find out if there's a Palmer Chiropractic graduate near you.
Re: Neck Pain
W.C. Turner
>Unfortunately my Chiropractor retired a couple of years ago.
I raised my PM3520A 5" when I first got it, 3 yrs. ago.
This is the first time this has occurred to me. I think there's many contributing factors here, many of which have been mentioned.
One thing I failed to mention, I was trying to complete a bowl from Silver Maple, that I was taking particular pains with, & was taking way too long. I kept getting tearout on the outside of the bowl, and I was getting tired, & instead of quitting, I wanted to finish. So, I think a combination of a lot of factors, is the culprit here.
Silver Maple is in abundant supply here, & in my woodpile, but, for my next bowl, I think I'll select a harder hardwood. I think that will solve my tearout problem, and ease my neckpain.
Thanks,
W.C.
Re: Neck Pain - Feel better W.C.
Re: Neck Pain
Dave Belser
>That proves it. Tearout is a pain in the neck!
- Dave :)
Re: Neck Pain
georgetroy
>WC, in my opinion your lathe is too high unless you are 6'4" plus. I like the gouge handles at my hip and waist line, not up there above my shoulder. GT
Re: Neck Pain
W.C. Turner
>georgetroy,
I'm 6'2"
Dick Hines
Re: Hello W.C.- I can help !
Dick Hines
>I have never had any trouble with my neck but did have a bad bout with a inflamed nerve in my leg. You turn with your leg. NO! I was turning a big chunk of unbalanced wood and the bowl gouge was jumping around a lot. So I had the bright idea to place the handle on my leg. Right where the leg meets the body. BAD MOVE!!
It did ok and I finished the bowl. Two days I could not pick up my foot more than 6" off the ground. After 3 weeks I went to the DR. Everyone knows how guys like to go to the Dr. Ahy way there is a nerve that run down the leg right where I had put the gouge handle.
After a couple weeks of drug treatment and no turning it got better. Needless to say I don't brace my bowl gouge on my leg any more.
Dick Hines
Dick Hines
>W.C. my father broke his neck and I can tell you you don't feel muckh of anything and it takes years to get over it.
I Used to think......
W.C. Turner
>that when anyone broke their neck, they expired, right then, and there, on the spot! Still do, kinda.
Dick Hines
Re: I Used to think......
Dick Hines
>It depends. If they just break the bones and don't cut the nerves to the brain they can live. If they cut the spinel nerves most times it's lights out.
