Just curious
Carole Valentine
>How many of you do most of your finishing while the piece is still on the lathe?
I never apply finish while the piece is still on the lathe.
Just curious
Carole Valentine
Re: Just curious
Ron in Drums PA
>The only thing I finish on the lathe are pens. Everything else is finish off the lathe.
Re: Just curious
Scott Hurley in N. VA
>I do small things - mushrooms, some boxes, Christmas ornaments, etc. on the lathe. But I do bowls and such off the lathe.
Scott
Re: Just curious
Richard Allen
>Most everything I turn is finished on the lathe. At the very least the first coat of finish is applied and the drying "pushed" on the lathe. I tend to work 14" to 20" platters, bowls and canisters. This mostly has to do with "pushing" the drying of the finish. I am looking for the friction and heat that I can get from the piece spinning on the lathe
Re: Just curious
Norm Smith in Nova Scotia
>Hi Carol,
I finish most of my small stuff on the lathe with Shelawax and EEE.
Norm
Re: Just curious
Russ Fairfield
>Just to be different, I finish EVERYTHING on the lathe. The spigot on the bottom is the last thing to go.
Re: Just curious
Allen Neighbors
>Carole, I finish almost everything I turn on the lathe. I cover the ways with an old t-shirt. When I put the final finish (it's really not final) on a piece, I leave it in the chuck, and remove the chuck from the lathe, so that finish can set. Then I put on another chuck to final turn the bottom of a previously finished piece, or start turning on another piece. What this means is that I try to always have a piece to finish the bottom on, or another blank ready to turn.
When you do it like that, you have to apply finishes in two parts, but it is faster for me to apply the finish when the lathe is spinning. Sometimes I have to do a little extra cleaning on my face shield, but that's one of the hazards of spinning... :o) I also need more chucks!!!
Allen
Re: Just curious
Jim Shaver Oakville, Ont.-Let's Go Oilers!
>Hi Carole,
Like most people I do almost al my finishing on the lathe. The Beal is about the only off the lathe finishing I do.
Take care,
Jim
Re: Just curious
Denis Lalonde Oshawa, ON
>I finish everything on the lathe and then buff oof the lathe...
Re: Just curious
Rick Davenport
>For what it's worth,
I finish my bowls on the lathe.
first with Mahoney walnut oil,
then with a walnut oil/wax mix from Mahoney,
then occasionally buff with beall when I want a bit of shine.
Rick
Re: Just curious
Bill Stehman
>I have always finished everything on the lathe... very low rpm's.
Re: Just curious
Ron in Drums PA
>Looks like I'm the odd man out.
I may spend 1 to 3 weeks working on a finish. It's not unusual for me to have anywhere from 2 to 6 pieces on the bench that are in some state of completion.
Re: Just curious
Wally Dickerman in Arizona
>I do just about all of my finishing on the lathe. After the turning, sanding etc. is done I apply a heavy soaking coat of oil. Most of my turnings are done with a glue block and screw chuck. I wait until I have several (4 to 8) pieces to apply a 2nd, 3rd or more coats to. I do them all, one after the other. With a 9-inch handwheel and the screw chuck I can put them on and take them off in a couple of seconds to polish with t-shirt cloth until they are dry. Been using this method forever.
Wally
Re: Just curious
Gil Jones on Lake Seminole GA.
>Carole, I finish nearly everything on the lathe.
Buffing is done off the lathe.
Re: Can't do legs on the lathe..
>or stretchers, stiles, etc. Besides, between staining and the many coat of finish....
Re: Just curious
>Carole I finish some things on the lathe and some things off the lathe. It depends on the finish. I usually put a layer of sanding sealer on while on the lathe. For wine stoppers I finish on the lathe totally. For mirrors some are on the lathe and some are off. Bowls that I apply Walnut oil are finished on the lathe. Lacquer bowls that I want to look satin and natural are finished on the lathe. Glossy bowls and vessels are finished by hand off the lathe.
Re: Just curious
Earl Eyre
>Off lathe. I try to get a very smooth, deep finish and at the least it takes several days of successive coats. Guess it could be done on the lathe but I don't want to tie the lathe up for that long.
Recently, I've put a couple coats of finish on, then used the Tripoli on the buffing wheel to get it smoothed down, couple more coats, then all three buffing wheels. Got a wonderful finish that way.
Earl
On The Lathe
W.C. Turner
Mostly Off the Lathe
Ric Taylor
Finish? Who actually finishes anything?
>Unfortunately, some of my things go into the "Hmmmm, I don't think so pile..." and never get a finish. Some things I finish on the lathe and some off. I use a vacuum chuck to spin bowls for finishing. I like the idea of leaving the chuck foot on, may give that a try. Thanks for a good post, this is an interesting question.
Re: Just curious
David Breth
>The only finish I apply on the lathe is wax. All the rest is off the lathe.
David B.
Re: Just curious
robo hippy
>My utility bowls all get the walnut oil, and beeswax finish, and final spin with the synthetic steel wool pads, on the lathe of course. When finishing green turned burl pieces I sand and finish them (Deft oil)before drying while still on the lathe. When dry, it is impossible to sand any more because of wild movenent, but I will apply more oil and wax. Sometimes I will put them back on the lathe, sometimes not.
robo hippy
Re: Just curious
Brad Vietje
>Great question, Carole,
That can depend on the finish used, and the shape of the piece, too. I usually apply finish on the lathe except for natural edge work, on which I usually do some hand sanding off-lathe anyway.
Safe Spinning,
Brad Vietje
Newbury, VT
Finish causes too much smoke in the woodstove ;-)
Brad Vietje
