Spindles:1 1/4 x 8 vs 33 x 3.5
Ed Moore
>How does one handle having a 1 1/4 x 8 chuck and then obtaining a lathe by a different manufacturer who uses the metric 33 x 3.5 for their spindle?
Ed
Re: Spindles:1 1/4 x 8 vs 33 x 3.5
Wally Dickerman in Arizona
>Ed, most if not all chucks have a threaded insert to fit a specifice spindle size. This can be replaced to fit another spindle size. About $25.
Wally
Ed Moore
>Wally,
I have not noticed that Vicmarc chucks have a 33 x 3.5 insert available. So, I checked a foreign distributor and apparently they do exist. I have not noticed that Oneway has inserts for any chucks other than their own.
I also just checked The Woodturner's Catalog and they do list chucks for 33 x 3.5 spindles.
So, my question was a result of not being observant.
Ed
>Oneway does offer inserts in different sizes. I purchase one in 1"x8 for our club and my best friend has thier chuck in 1 1/4x 8. I have vicmarc and have all sizes but the 33 size. I think I bought an adaptor to go from oneway to my vicmarc but I'll have to check to tell you for sure.
Brian McKearney
Brian McKearney
>Just be careful, because in my experience, I have found that not all manufacturers make M33x3.5 inserts for their chucks. I think that you will be fine with Vicmarc and Oneway chucks, but I own an "original Nova" chuck and could not purchase an M33x3.5 insert for that particular chuck when I bought my 1640. I could have purchased a spindle adapter, but I didn't like the idea of that so I ended up getting a Vicmarc chuck. This may not apply to all Nova chucks, but it was the case for the "original Nova" chuck (tightens using tommy bars).
So, while most manufacturers offer a variety of inserts for their chucks, it doesn't seem safe to assume that all manufacturers offer a full range of inserts for all popular lathes on the market today.
Brian
Get a spindle adapter
Paul Porter in Phoenix, AZ
>I have lathes with different size spindles and I use adapters to interchange chucks and face plates. Also, I demo a lot, so I have adapters to fit other spindle sizes I don't have.
Allen Neighbors
>You're right, Brian. I have two Supernova2 Chucks, and a Oneway 1640 on order. I can't get an adapter that will fit the SN2's to the Oneway spindle. Had to get 1 1/4 inserts, and then two spindle adapters in order to adapt both my lathes to the new insert size. I'm only hoping for the runout to be minimal...
I think I'm going to opt for a couple of Oneway Chucks or a couple of Vicmarcs... but that's going to have to wait a while. I first have to make Sweetie Marvel with open jaw over some of the turnings that come off the new 1640 before I can spring for the new chucks to match... :o)
Allen
Re: Get a spindle adapter
Don Evans
>I agree. I purchased a 2436 and there is no way I was going to replace all the inserts I have with the quantity of things I have in 1 1/4 x 8.
So I got the adapter from Oneway and it is as usual of high quality and should be no problem with using it. It also locks on spindle with allen screws so it just becomes part of the lathe.
Don
Bob Fawcett
>Are the Oneway adapters drilled?
I have an adapter from another source and it is solid. This means no vacuum chuck. Have to make the vacuum chuck the same size as the spindle.
The Oneway adapter I have...
>...is drilled with a #2 Morse taper. All my vacuum chucks are 1x8 and it works great with those.
Re: Bob Fawcett
Allen Neighbors
>Bob, I bought a couple of Spindle Adapters from Bestwood Tools, and they weren't drilled with a through hole or set screw when I got them. So, I checked the hardness, and drilled both of them through, by starting small, and working my way up to a 7/16th bit. No morse taper, but it'll work with vacuum...
I drilled and tapped one for a set screw, using it on my Grizzly, and I'll drill the other one for a set screw, also, but I want to wait and mark it after my new lathe gets here, so the screw will match the flat on the spindle.
Just wanted you to know it can be done. :o)
Allen
