The white oak bowl is dry. *LINK*
Dave Smith, Longview, WA
>If you are interested you can review the data and chart on my blog.
Dave Smith
Still have an other panel to glue up before bed in Longview, WA.
Alcohol Soaking Blog
Dave Smith
Re: The white oak bowl is dry.
Brad Thompson - Hartselle AL
>Dave,
You blog data showed a pre and post alcohol percentage. How do you measure that?
I started using your method a couple months ago and am a true convert. Thanks for the great information.
Brad
Wish you wouldn't have asked that.
>Hi Brad,
I use weight to determine the alcohol concentration. I could buy a hydrometer but I wanted a simple way to ballpark the concentration using some thing I already had and not as breakable. Shawn Bearden worked out a chart for me that uses the weight ratio of water to the soaking solution. I have a basic procedure written but I haven't taken pictures yet. I need to refine the procedure and make it as sailor proof as possible. I have given a handout of the procedure and graph at the presentations I have made to turning clubs. Sounds like you are volunteering to check the procedure for me when I get it ready for publishing.
Dave Smith
Public service doesn't pay very well in Longview, WA.
Re: Wish you wouldn't have asked that.
>Hi Dave,
The primary reason for asking was that I have been wondering about my solution.
Even though I would top it up, it seemed to be less effective with subsequent soaks. Not being a chemist, there was a tickle in the back of my mind that the water had to be diluting the alcohol to some extent.
Would be happy to assist in anyway I can.
Thanks again,
Brad
Solution does increase in water %.
>Hi Brad,
I'll shoot you a copy of the draft procedure and graph. The procedure assumes you have a scale capable of reading in 1 gram increments. Let me know what you find out or if the procedure is understandable. As stated in the silktree blog I have successfully dried bowls in solutions as low as 50% but I don't recommend it. My most spectacular failure was madrona soaked in 50% alcohol.
Dave Smith
Flat work still paying the bills in Longview, WA.
Re: Solution does increase in water %.
Russ Fairfield
>Dave, you need to give instructions for making a still to reclaim the alcohol. Be sure to add the disclaimer that it up to the user to convince the ATF agent that this is a ligitimate woodturning technique.
That is in the second DVD.
