THE WOODRAT IS BACK!
Trends Airsheild???
Trends Airsheild???
Trends Airsheild???
Paul Hammer
>Well after being on 2 other forums today and here i have learned alot about dermatisis, breathing problems eye problem and even death from working some woods. In saying this i think 320 dollars is a lot cheaper then a ER trip. Does any1 here use the Trend Airshield? Do they like it? Does it get hot? Is there anything beter?
Wood is like snakes. The most beautiful 1s r the most deadly lol
Re: Trends Airsheild???
Steven Potts
>I own a Trend, I like it better then the belly pack ones. If you buy one I suggest you buy an extra battery. The one it comes with last about 4 hrs give or take. The temperature of the air it pushes across your face depends on the temp in your shop. It is also good to buy extra pre and post filters. These cost, but again its your health. All in all, I wouldn't turn without it.
Carole Valentine
>I have one. I don't wear it too often because I have to tilt my head down more to see with it on, and my neck begins to bother me after a period of time. In the summer, the air moving across your face is nice, but I have an unheated shop and in the winter it just about frosts my nose! Does a good job of filtering.
Colin Spencer
>Paul
I have one and now use it all the time. It takes a bit of getting used to with the additional weight on your head, but persevere it is worth it. The only problem that I have with mine is the head band in that it tightens around your head to stop it moving, sometimes I have tightened it one notch too far and ended up with a headache! The second battery is worth it but if you are handy with a soldering iron you can make one for a lot less.
Colin
Re: Triton
>I have the Triton. It has a few advantages. For starters, it is less expensive. It also includes a hard hat, hearing protection and protection for the upper chest and neck. The filter and battery pack are on your belt, so there is less weight on your head, and the air intake is much removed from the sources of dust and shavings. It works well for chainsawing, as well as for turning and sanding. A minor disadvantage is it a bit more hassle to put it on, and the face shield can temporarily fog a bit while you are connecting the hose to the filter. Once on and running, I find it very comfortable. I think it is a viable alternative.
OB O'Brien
>Any one know the specifications for the size of the filter in microns? Does it remove the little stuff, or just the nusiance dust?
OB, I use the little one
TDaniel
>The Trend Ace is under $100, filters to .5mfd, and has no battery to charge. I switched to it from a 3M Raccal and like it better. I bought mine at the Atlanta Woodworking Show for $77.
TD
Re: Trends Airsheild??? *LINK*
LT
>Paul,
I've had a Trend Airshiled for over a year now and highly recommend it. I don't find it to be heavy or cumbersome and I wear it all the time when I'm turning. I would suggest the extra battery and the extra visor overlays. Also, I purchased mine from All Pro Tools. They currently have it for $249.90, but I have seen it on their site for as low as $216. No affiliation, just a satisfied customer.
LT
All Pro Tools
Fog Tanner
>I used a Powervisor, which is basicly the same as the Airshield, for several years. It is OK for nusience dust, but you cannot get the submicron filters for it. I now use an Airstream any time I am turning.
I have allergies to some woods, Cedar being one, which I turn a lot. With the Airstream, I have no problems at all and cannot even smell the wood until I take the helmet off. After doing a lot of research on dust problems due to my allergies, I elected to get the best filtering I could. I do have visions of not carring around an oxygen bottle when I am in my sixties. And the price of the Airstream was chaper than a new set of lungs.
One of the other reasons I got the Airstream, was the helmet. After bouncing a couple of box blanks off my face shield, I figured it was only a matter of time before one bounced off my skull. Again, I figured the Airstream was cheaper than a trip to the hospitial.
Good luck on your quest, I went through the same thing. Finally I just bit the bullet and bought one.
Peter Charles Fagg (UK)
>Paul, I have used the Airshield for some time and can highly recommend it for dust extraction and portability. It does get a little heavy after about 4 hours and it is a pain that after 14 hours of charging the battery packs last about 4. Please consider purchasing a second pack of batteries it will be easier in the long term.
Nevertheless it is a wise investment.
Regards Peter.
Gary R
>I just purchased my airshield a few months ago, and it came with a black battery pack containing NiMh batteries (I believe 700 mAh). These are much improved as you can re-charge anytime, with no memory effect.
The original units shipped with NiCad batteries.
I purchased a plug from Radio Shack, and battery holders from Mouser Electronics to make my own. You can get 4 2200 mAh batteries, with a charge for less money than Trend wants for a pack. I plan on getting two sets of the Energizer 15 minute charge batteries. I'm not sure on the mAh rating of the original NiCad packs, but my home built is three times the run time of the supplied pack.
Have not used for an extended session, but I'll post the results.
P.S. My pack fits into the Airshield better than the units originally supplied. I need to almost force that one in the compartment. Mine just goes in nice and snug.
>Reading your post, I just wish that I had the expertise and know-how to make up my own packs here in the UK!
Regards Peter.
I wouldn't...
Don in Northern Arizona
>buy one if I was working with really poison woods or had strong allergies. If you go to the Trend site you will find the following:
"This unit does not carry any respiratory approvals for sales in North America and Canada. Head protection: NOT an industrial safety helmet."
Seems like a lot of money and inconvenience for something with the above disclaimer.
It is twice as expensive, but the 3M Airstream mentioned earlier is much safer for your lungs and your head. I am saving for one.
I have the old 3M Powervisor like Fog Tanner and don't use it anymore as it did not filter the small stuff and I often found myself with a dusty hankerchief.
Don
Re: I wouldn't...
Paul Hammer
>Well Thx every1 4 the input. Today i bought a Airshield. It is charging now. I dont know if i can get threw the day without trying it haha. I will have to let u know what i think.
Happy turning
Re: I wouldn't...
Ralph
>Don
The Trend disclaimer is regarding the use with vapors, ie finishes. Not wood dust.
What battery??
Gary R
>Hello:
Congrats on the purchase.
Just wondering what battery came with yours.
On the sticker, it will be NiMh of NiCad.
Thanks
Re: I wouldn't...
>Ralph,
You are correct that they specifically disclaim vapour protection, but they also don't explicitly proclaim to protect against fine dust to a specific national standard on their approvals page. The only spec listed as being met on their site is one for eye protection, ANSI Z87.1. If there really is no NIOSH or ANSI standard for dust protection, then I would feel safer wearing protection that met vapour standards. I just want to make sure anyone with a real dust problem like me is aware of this.
Don
Re: What battery??
Paul Hammer
>NiMh battery
Re: I wouldn't...
Fog Tanner
>There is a NIOSH standard for dust protection. One reason your will never see the Powervisor of Trend with that rating. Among a couple of the standards are filtration and airflow. The minimum airflow is 6cfm for the duration of use. The Powervisor starts out at about 6 and quickly drops below that, within a few minutes. The Airstream starts out at +6/+10cfm depending on model and stays there for 8 hours. The Airstream also filters down in the submicron catagoery, which the Powervisor doesn't. The submicron dust is what does the damage, if you can see it then your body can stop it. The submicron particles go right on through and into your lungs. The damage is cumulative and you may not notice it for years, in my case it was 20. Without a respirator, I would be carrying around a bottle of oxygen in another 15 years.
The respirators also have to be certified on an annual basis, which also cost some coins. So don't look for the Trend to carry the NIOSH ratings any time soon, same as the Powervisor. I found that out talking to a 3M tech guy when I was researching some different filters for my Powervisor.
And the Aistream, with the standard filters, does not protect against vapors such as finishes. For that I use a respirator made for painting.
Colin Spencer
>Peter, It sin't difficult. Maplins (I think that there is one in Portsmouth) carry all the pieces necessary. What you need are 3 nicad/mimh batteries with solder tabs on them and a power connector two pieces of wire and a soldering iron. I have always found Maplins staff helpful and am sure if you take a battery pack in with you they will give you the parts. If you can't solder I am sure that one of the TV repair or even marine electronic repair businesses on the Island will make it up for you for a drink. Unfortunately now living so far away I can't offer to do it for you. I got the bits to make mine from Maplins on a trip to the UK about a year ago.
Colin
Re: Triton
eliot
>I use the Triton and agree with what has been said. One problem I have with it, though, is that they can't seem to manufacture the clear plastic face shield so that it's distortion -free. There has been a slight distortion in two face shields that Triton sent me after I complained about the problem.
