Have a question? Ask Woody!
Pink or White?
Pink or White?
Pink or White?
Allen Neighbors
>I'd like to hear some opinions on the pink grinding wheel (Woodcraft #127253 120 Grit) and white grinding wheel (Woodcraft #01W48 60 Grit).
They are both the same price.
Does anyone know if they have 1" center holes? I know I can call Woodcraft and find out, but this is Sunday, and I'm curious today... tomorrow, I'll probably forget about the curiosity. :o)
I've ordered the Oneway balancing system, and need to order wheels that have the one-inch center hole, and I'm also curious about what grits to order.
Allen
Still waiting for the 1640 to make the trip...
Re: Pink or White?
Re: Pink or White?
Steve Worcester
>Pink, won't load up as fast. They are made by Camel (CGW) and it has a 1" hole.
Steve Worcester
www.turningwood.com
Re: Pink or White?
Re: Pink or White?
Gil Jones on Lake Seminole GA.
>Al, I use a pink 80 and 120. They work fine, but you should have one of those 'T' shaped diamond wheel conditioners ($15) to keep the wheels clean and true.
Re: Pink or White?
Re: Pink or White?
Barry Turner
>I have the 60 grit pink. I like it. I still have the 120 grit white that came with my Delta slo-speed grinder. It loads up pretty bad and overheats edges. I plan to replace it with a Woodcraft or Norton white wheel...probably 100 grit or maybe another 120 grit.
Re: Pink or White?
Re: Pink or White?
Allen Neighbors
>Thanks to all for your responses. I appreciate them.
Put 'em all together, and they satisfy my curiosity, and help me to make decisions..
Gee, I love this forum!!
Allen
Re: Pink or White?
Blue
Bob Fawcett
>Go for the good stuff, get a Norton SG wheel. Probably last you a lifetime. It doesn't wear near as fast as my white wheel did. Cuts great and leaves a great edge.
Re: Pink or White?
Re: Blue
Allen Neighbors
>Where do you find those, Bob?
Re: Pink or White?
Re: Blue
Bob Elliott
>I got mine at Craft Supplies. Only problem with that wheel (at least the one I bought a few years back) is that it has a 1/2" hole and I am not able to use the Oneway balancing system. I think with their system you need a 1" hole?
I do like the SG wheel.
Re: Pink or White?
Re: Blue
Mark Kauder, Phenix City, AL
>Alan,
Go with the Blue SG wheel. I have tried most of the others - all price ranges. Last fall, I took the plunge and spent $100 on a blue SG wheel. It is sweet!! Does not load up guickly, and does not wear quickly. Well worth twice to three times the price.
Mark
Re: Pink or White?
Re: Blue
Allen Neighbors
>Mark, how are you getting along, Sir? Hope you're staying busy, and that the kids are doing well.
Speaking of Grinder wheels, I don't mind the extra cost for quality, but I do want a wheel that has a one-inch center hole, in order to use my Oneway Balancing System.
Thanks for responding... blessings to you.
Allen
Re: Pink or White?
Re: Pink or White?
Russ Fairfield
>Grinding wheels are a personal experience, and you will get differing opinions and experiences from different woodturners. Here are mine.
I recently bought 2 of the Woodcraft 80-grit wheels. They have a 1" hole that was a tight fit to the hub on the balancers.
HOWEVER, the wheels were about 3/32" out of round, or the center hole wasn't in the center, the result was the same. AND they were still out of balance after truing. You will definitely need the Balancers to get the best performance from these wheels.
After that, they are fine wheels; but I wonder if they were worth the savings.
There is one difference between these and the Niagra wheels that I have always been using. They are not as friable as the Niagra wheels, and that means they load up more often and require dressing more often. The weaker bond on the Niagra wheels allowed the worn abrasive to break away, and the only time they required dressing was when they were no longer flat, never to clean them. Yes, they do wear faster, but not having to dress the wheels several times a day made that a good compromise for me.
Measured in time, I was having to dress the Niagra wheels once every 3 or 4 weeks, and now I am having to dress the Woodcraft wheels at least twice a day for the same amount of time at the lathe.
Re: Pink or White?
Re: Pink or White?
Russ Fairfield
>You cannot compare the colors of the wheels from different manufacturers. The only thing that has any meaning is the "Number" on the wheel. When the numbers are the same, the wheels are the same, regardless of their color.
All white wheels are Aluminum Oxide, but not all Aluminum Oxide wheels are white. Different manufacturers use different colors for their inventory control, and it can denote either the grit or the binder that holds the wheel together.
Re: Pink or White?
Re: Blue
Bob Fawcett
>I don't think it has the 1" hole. The label is pasted over the bushing if there is a bushing.
I got my wheel at craft supply. Although I haven't tried the Oneway balancers, I can't complain about the balance of the SG wheel. I have a 28 year old Jet 8" grinder and it runs smooth with the SG wheel. I can't see any wear to speak of on my wheel at this point. I think it will easily last 3 times as long as a $30 wheel.
I have a hard felt buffing wheel mounted on the other side of the grinder and I use that with green compound when I feel the need to hone.
Re: Pink or White?
Re: Blue *LINK*
Bob Fawcett
>Here is a link to Craft Supply. I got the 80 grit. No problem reshaping a bowl gouge to a long grind.
SG wheels
