Have a question? Ask Woody!
Re: non-slip mat...a follow-up
dwfII
>Thanks to everyone who replied. I went to Walmart looking for "foamies" or router pads or shelf liners...anything. Ended up with a thin mouse pad..."Mouse Mat" I think it was called. Works great.
I have another question regarding this process...the opening on my hollow form is roughly inch and a half. Taking note of warnings about breaking using a true jam chuck, I turned a shaft long enough to go to the bottom of the vessel and tight but not jam tight at the lip. Then I chucked the shaft, trued it, and slipped the vessel over it and brought up the tail stock.
Now I have done this several times, and theoretically, the bowl should run true. But it never does. There is always a very slight idiosyncrasy. I have never been able to eliminate that--the tail stock prevents me from adjusting the position. I generally go ahead and finish the bowl or hollow form and any discrepancy is pretty much invisible but it makes me think I am doing something wrong or that there might be a better way.
Does anyone have any ideas or tips in this regard?
DW
In the High Desert of Central Oregon
Re: Re: non-slip mat...a follow-up
Allen Neighbors
>DW, glad the mouse pad works for you. I use a little piece of the same material, with a home-made, adjustable-length, shaft.
Your problem with the vessel not spinning true, is my problem also, and I can't seem to solve it, either. I wonder if it's an alignment problem. I'm using my old Grizzly (for a few more days :o)) and I think it might be because the lineup between tailstock and headstock isn't perfect. I also think that part of the problem could possibly be solved by the Oneway.
I'm glad you posted this question, though, maybe we'll both get some help.
Thanks for posting.
Allen
Carole Valentine
>"I also think that part of the problem could possibly be solved by the Oneway."
I wouldn't bet the farm on it! That sounds like "justification" if I ever heard it, Allen! ;))
Wood moves - a lot quicker than you might expect. Even dry wood. Hollowing releases stresses in the wood and a 1 1/2" opening (or the whole piece for that matter) that was perfectly round when you cut it can very easily be oval by the time you finish hollowing. It is a rare thing for me to be able to reverse a piece to finish off the bottom and have it run absolutely true. I have gotten really good at blending. LOL
dwfII
>Well, this is comforting, at least. If others, almost all of whom are far more experienced and skilled than I am, have a similar problem, I guess I can live with it.
It could be my Jet, I suppose, but I have checked alignment every way I can think of and it looks good...so, I'm more than ready to accept that wood movement is the culprit.
I, too, am getting pretty good at blending.
DW
Bill Hale
>Not solvable with a Oneway!
I Have a Oneway 2436 and I still have the problem. The only thing I would guess it to be is that the initial tailstock location moves as we finish turn the piece. That in itself would be all it takes. I just don't wory about it. If you did your final cut on the base while in the jaws they will be flat to the bowl. When you reverse just cut inside the base lip, any woble should not show on the finished piece.
Good turning and be safe
Bill in Dolores CO.
Allen Neighbors
>Sometimes justification becomes necessary, Carole. :o) I think you may be right about wood movement being the culprit.
However, Bill Hale may have hit on a close solution to solving the problem. Save your last cuts to the bottom to just immediately before you reverse, and the piece may not have the time to move much on you. I'll give that a try on my next piece, (if I can remember to).
Allen
Just a few more days.........
If that works ...
Bob Fawcett
>you can still say it was the Oneway :-)
Re: If that works ...
Allen Neighbors
>Thanks, Bob. That's a good idea! :o)
Allen
Darryl Hansen
>Since we are talking about a hollow form, probably can't see the inside bottom. Is it possible there is a small "nipple" in the center of the inside bottom that the jam shaft is riding on? Just a thought.
dwfII
>That's a good thought...and one to definately keep in mind. In this case, the opening is at least two fingers wide and I can see to the bottom. I can even feel the bottom. What's more the neoprene friction pad ought to absorb any small nipple...shouldn't it?
DW
Re: It would if it's thick enough.
Allen Neighbors
