Question
Barbara Gill, Remlik VA
>What tool would you use to turn small beads on a plate or platter?
Question
Re: Question
Ron in Drums PA
>I use the long point of a skew
Re: Question
>How about a parting tool.
Re: Question
Jim Pugh, Ohio
>Barbara, use your 3 point tool. There is a video clip by Stacey Hager that shows the use of this tool, including making beads on the sides and faces of bowls/platters.
Unfortunately, I don't know how to link to the video so someone else will have to jump in here.
Re: Question
Lee Dale
>Barb.. I use a parting tool ground like a beading tool for snall beads and my 3/8 Sorby bead tool for large ones as well as making a tenon for my Oneway chucks...Lee
Re: Question
georgetroy
>I use a beading tool I got from Dale Nitman, these are the ones he makes his beautiful platters from. I guess just google for more infor. GT
Re: Question
Allen Neighbors
>I use a little 3-point tool. I can't remember the video I saw that showed how, but it's a sort of a handle-raising/rolling movement that makes the cut really easy. I begin with a tool bevel level, handle low, and the point at the equator. (Does that make sense?)
Allen
Re: Question
Gil Jones on Lake Seminole GA.
>Barbara, I reground three old bench gouges to the same shape as pictured on WoW by Basil Kelsey, and they work pretty well if you are carefull >> http://www.thewows.com/isapi.dll?c=Content&htx=View&siteid=G6kOAI&contentid=ZZZZZJQZ&contentclass=PICT&categoryid=8
Re: Question
Pete Kekel - Kentucky
>If it's just a single bead, I'll define the area with a thin parting tool and then finish it off with a 3/8" spindle gouge with a long fingernail grind.
I think the AAW site had the video of the 3-point tool mentioned in some of the other posts.
Thanks For the Responses Guys.
Re: Question
Carole Valentine
>I guess you have already gotten your answers, Barb, but I do it like Pete does except I use a little 1/4" skew that Ed Moore made for me to define the bead then do the shaping with a spindle gouge that I have ground into more of a detail gouge. I screw up quite a few of them, though! LOL
Thanks Carole.
Re: Question
>Thanks to Trent Bosch for teaching Basil Kelsey how to make, and use these bead forming tools. I made a similar three piece set (from old carving gouges), and they work fine.
