end grain tool suggestion
utnixon
>I am planning to try some end grain work (vases, bowls). Some hollow forms but not really narrow necks. Any suggestion regarding tool specifically sold (with great sale description) for end grain work. Any comments about Pro-Forme, Berger, hook type tools, etc. will really be appreciated.
Thanks, Bill
Re: end grain tool suggestion
Bill Howatt
>I certainly wouldn't consider myself an accomplished end-grain turner but I use a Oneway Termite and like it although you have to take care to get an even wall thickness. If possible I use it as a roughing tool and then clean-up with a scraper. This naturally can't work with all shapes/openings.
Bill
Ed Karch
>Berger tool gives nice smooth sides and a square bottom.
Jake Niedling
>Well I would not go out and buy special tools until you have turned a few with your spindle & bowl gouges and scrapers. You can do a pretty good job without the special tools. I have seen Al Lacer demostrate his hook tool and played with it a little and found it to do a nice job on final clean up cuts on the inside.
Kevin Gerstenecker
>I'll second what Jake mentioned. I watched Alan Lacer build and demonstate a hook tool for cutting end grain. I was impressed how well it cut, and the small spaces you can get into with this tool. I have made several of these tools as Alan showed us how, and they work great. For end grain, the "Lacer" type hook tools I made are all I use. There are instructions for making them at Alan's website.
