Speaking of live centers
Carole Valentine
>Can someone educate me and tell what the centers with the yellow question marks in the pic should be used for?
Carole Valentine
Opp...wrong pic
Carole Valentine
They're used for wood turning Carol -Sheesh!
Ray Carson, New Jersey
>I'm curious too being a returning novice to the round world.
Re: Opp...wrong pic
Ed Moore
>Carole,
I think that the small part on the left fits in the second center from the left. It serves as a flat surface that will rotate. I use a similar one quite often to hold boxes or lids in place while reverse turning.
The one to the right looks as if it will accept a tenon, which could be really useful when reversing a bowl. The remaining center looks as if it would accept a cone, which also could be great when reversing a bowl.
I have the older version of this set, or a very similar one, and I think it is very versatile and useful. Go for it!
Ed
Re: Opp...wrong pic
Ed Moore
>I'd love the edit feature right about now. The center that would accept the small part on the left is the THIRD center from the left.
Ed
Re: Opp...wrong pic
Dick Hines
>The little one on the bottom left is used in the big one, third from the leaf, to keep from putting a hole in the bottom of a turning. I am not sure about the other 2 but They may be for the same thing.
Re: Speaking of live centers
Wally Dickerman in Arizona
>The one one the left looks like one I once made to fit a Delta live center. It was used to center a piece where a screw chuck had been used.
Wally
Don Evans
>Carol:
The one others aren't sure about, second from right inverted cone one.
It is used for square ended items, they become self centering with this type adapter.
It can be used for other things of course, like a round tenon and also would self center.
Don
Re: Opp...wrong pic
Clay Foster
>Their most effective function is prying money out of a woodturner.
Carole Valentine
>Thanks for the info, everybody! This is the Sorby set (reasonably priced at $79, I thought.) I received it yesterday but it included two ring centers and no inverted cone. CS is going to swap parts with me. BTW...I ordered via USPS Priority rather than the usual UPS. It was cheaper and got here from Provo in 3 days vs the normal week+ for UPS ground.
Look at page 24 of your Sorby catalog
>Carol. I just received my catalog from Sorby and it has a very nice illustration of the the different center usages. The catalog comes with 2 interactive CD's too.
Ray
>The pin is, I believe, often used for spindle work that has been drilled. The pin is 1/4" or 3/8" yes? One way to keep a hollow spindle perfectly centered while turning the profile is to drill the blank with a drill press, then use the ends with a pin-chuck/pin-center combination to keep the drilled hole precisely in the center of the work piece; also good for making tool handles. I've heard instrument-makers (flutes, etc.) work that way and then use a center-guided reamer to finish hollowing the interior. Similar use for the far-right cup center which accepts/holds a tenon.
Jim
>Looks to me like the two on the right are what they call "cup" centers.
They're used for quickly centering rounded end spindles and the like (think handles) that have already been parted off, so that you can re-work them without marking them up too bad like a pointed center.
Am I wrong?
Re: Look at page 24 of your Sorby catalog
Carole Valentine
>Guess I will have to request a catalog again.
>The inverted cone will take a ball or round tenon smaller than its outside diameter and auto-center it; there will be some scuffing of the surface and compression of the fibers at the contact point-ring. The cylinder "cup" is, I think, only useful for a tenon that's turned to fit it precisely, but it could also be used with a larger steel pin.
Re: A new catalog
>Carol,
I tried snapping a PIC but in my haste here at work it didn't come out very well.
The two video CD's are neat. They give a brief video of several of Sorby's tool usages. Nice.
The catalog doesn't have prices though...what's up with that?! That screams expensive. :-)
Ray
Re: A new catalog - a better
Mac
>Thank you Carole, part of that went towards my retirement pension....
Carole Valentine
>You're welcome Mr. Postman! Wouldn't want your pension to get in trouble now, would we? ;)
Russ Fairfield
>I have to agree with Clay. These things are there to make us buy. They have nothing to do with their utility. They are no different from turning tools in that respect.
It always seems odd that I was able to get along for years with a plain cone center and a couple different sized washers to limit penetration into the wood. The only improvement was a drop of CA glue to keep the washer from falling off. Then the manufacturers convinced me that I needed several centers with different angles and a drawer full of attachments. Now thay all gather dust because I still use the same old cone-center and washers for most things; and I have no idea what angle it is because it doesn't make any difference. It even works in a pen mandrel so long as the hole in the end is round and in the center of the mandrel.
USPS
W.C. Turner
>I've known for sometime that USPS is faster service, & less expensive than UPS. I'm glad the word is finally getting out. If at all possible I will not use UPS.
Re: Speaking of live centers *LINK*
Phil Joines Krum, Texas
>These kinds of sets have been around for a long time as metal lathe centers. They are mostly usefull for turning small spindles. Differant sets come with various adapters. They were fairly common for wood lathes up to about the 1940's.
A set from MSC
