vacuum pump info
Mike Nelson
>I've looked for hours and can't find that $100 vacuum pump! Can anyone point me in the right direction? I only found one searching past post. thanks
vacuum pump info
Mike Nelson
Re: vacuum pump info *LINK*
Brian McKearney
>Try here Surplus Center.
Mike Nelson
>Thanks Brian! They only had about 1500 of these ha ha. Do you or anybody out there think this would work with my powermatic 3520? I'm kinda wondering about that 'thermally protected' part when I'm hanging over a 12" bowl..
1/4 HP Rotary Compressor Vacuum Pump
� New GAST 0523. Direct drive, oil-less, rotary vane vacuum pump. Motor is thermally protected and will restart automatically after the coils cool.
SPECIFICATIONS
� HP 1/4
� Voltage 220 AC
� Amps 1.5
� RPM 1725
� 4.5 CFM at 0 PSI
� 3.6 CFM at 10 PSI cont.
� PSI 15 int.
� 0.5 CFM at 26" Hg max.
� Ports 1/4" NPT
� Duty continuous
� Thermal protection on motor
� Size 5 5/8" x 13 1/4" x 6"
� Shpg. 31 lbs.
Mike Cunningham (Cape May)
>I've been using the exact pump from the same supplier for more than a year on my Vicmarc....no problems. Surplus also has the filter you'll need. The other fittings can be had from any hardware or big box. I purchased the EZ adapter from Craft Supply
Mac
>Have used this same pump for a couple years now, works just fine....
PM 3520 vacuum pump info *LINK*
Jerry Hall
>I just visited a friends shop who had a vacuum chuck system on his 3520A
He exactly followed the superb article by King Heiple in Woodturning Design Fall 2005 (back issues can be ordered.) It is very detailed and well written. Exact sources for ordering all needed parts and part numbers are provided. I just ordered the stuff for my PM3520a. The whole thing will come in under $200. He mounted his to the headstock legs. I may put mine on a little MDF cart so I can wheel it around for use as a vacuum press. He just has an extra long tubing line to do that if he needs to. He also ran the exhaust tubing outside which cut down on the noise a lot. One variation he did was to make an MDF faceplate with concentric grooves with weatherstripping to hold a wide range of plastic pipe sizes for vacuum chucks. The vacuum holds the pipe to the MDF chuck. Worked slick with 17psi of vacuum typically.
I can email you or post more pictures but here is one picture of his PM3520 installation:
Woodturning Design Fall 2005 TOC
Re: PM 3520 vacuum pump info Chuck Picture
Jerry Hall
>Ordinary sticky weather stripping in grooves if you look closely...
Re: PM 3520 vacuum rotary adapter
Jerry Hall
>Shop built rotary adapter. Feeds into head stock with a protruding short length of 1/2 inch pipe affixed to the adapter. Held on also by vacuum pressure against neoprene seal. Uses standard double sealed bearing. Rubber band holds adapter on when no vacuum. Obviously removes instantly for knock out bar or buffing threads-all fixture. Seems superior to purchased adapters, and the price is right - under $10. The above referenced article details the easy construction of the adapter.
How do you center the Adapter?
Gerry Meekins
>Cool adapter.. I may just have to try n build one of these. I had one similar to this that attached with set screws (could draw 28in with it). Of course the problem with it was always needing to remove it to use the knockout bar. With vacuum holding it on should be a breeze. Only question I have is centering it. Does the 1/2" pipe help center it when you install it or is there some sort of indexing pins?
Thanks for sharing this idea!
Gerry
Re: How do you center the Adapter?
Jerry Hall
>Gerry, You got it. The pipe centers the adapter nicely. It seems to me it doesn't have to be perfect, it doesn't drive the object being turned, it just needs to run smoothly. My observation is that it fits right for that purpose first time, every time. The pipe diameter you select should of course be a close, but easy fit inside the spindle. You should check the article, but it seems you just use glue and the pipe threads in a press fit dia hole in the mdf adapter. Jerry
Thanks Jerry, I'm gonna try it!
Gerry Meekins
Mike Nelson
Mike Nelson
>Thanks again all, Brian you saved me from buying a used one and for less $! My lathe is up against a storage rm wall in my shop, I'm thinking of mounting the pump inside the rm and running everything through the wall level with the head and mounting a switch on the lathe wall. Mike
HarryB
>Does anyone know of a 110/115 vac version of this pump? While I have 220 vac in my shop, it is not convenient to the lathe.
Harry
Carole Valentine
>They have transformer that steps it down. Seems it was $50 or so.
Yes
>I bought one from Surplus.
Transformer
Yes *LINK*
Transformer
