REAL MILK PAINT
Oil Removal?
Oil Removal?
Oil Removal?
Thad
>Is it possible to remove vegetable oil once the mistake has been made of finishing a bowl with it? If so, how?
Re: Oil Removal?
Re: Oil Removal?
Russ Fairfield
>The following is copied from No.13 of my finishing articles in Russ's Corner. It was written for a finish over Mineral Oil, but will apply to any oil that mixes with Mineral Spirits.
What finish can be put over mineral oil?
This question has been around for many years. There are those who say nothing can be put over mineral oil, and there are those who say that they do it all the time. As we would expect, the answer is somewhere in between.
Mineral oil is a petroleum product. In the simplest of terms, it could be described as highly refined and edible lubricating oil. As such, it does not dry when it is applied to the wood. Mineral oil is soluble in all petroleum based thinners and turpentine, and any finish that uses these same solvents can be put over it. Lacquer, shellac, varnish, and drying oils will absorb any mineral oil that is already in the wood into the new finish, and there will be no adhesion problems.
However, there is a penalty. The mineral oil acts as a "plasticiser", and the new mixture will cure to a softer finish than if it were used alone over bare wood. How much softer will depend on how much mineral oil is present. And, the softer finish will deteriorate with age much faster than if it were applied over bare wood.
If you are willing to accept this compromise, then the answer is that, yes, a finish can be applied over mineral oil.
Re: Oil Removal?
Re: Oil Removal?
Gil Jones on Lake Seminole GA.
>Not sure how this would work on a bowl, but it should. To remove oil from military rifle stocks, I heated the wood and then coated it with cornstarch (repeat until the oil is all out, or you get real tired of it). The heat forced the oil to the surface of the wood, and the cornstarch soaked it up. It worked for me, and stocks are somewhat thicker than most bowls. Cornstarch is very cheap, and I used IR heat lamps as the heat source.
