inside out platter
inside out platter
inside out platter
>Here is the inside out platter I finally got to photograph. I glued up the 4 square mahagony pieces and then inserted 2 36 sided rings of holly and yellow heart. Then I cut another groove and drilled 4 holes that intersected the groove. I filled this with clear Inlace that I colored black with india ink. Then I turned it a little, cut it into 4ths and reversed each piece 180 degrees. Then I turned a shallow bowl in the center.
I wish I had left it square instead of round. The holly had good contrast with the yellow heart until I put the finish on. Wish I had put black veneer between the yellow and white segments. fun and challenging to make but still needs more work to get where I want it to be.
Re: inside out platter
Ed Kelle
>Looks nice John. Have a lower angle shot? Seems to have some coves in the platter right?
Great work
>Ed It does have some coves cut around the outer ring. I didn't do much on this one because I was afraid they might affect the look of the rings. I am planning the next one specifically to find out how a series of coves will affect the rings. I suspect I'll get some interesting bisecting lines that will change the look of the rings. I'm going to do a test on wood without any inlays first and just cut a bunch of coves and raised beads on the first turning and then again on the second turning and see how they intersect each other and most importantly how the joints of these intersections appear. Then I'll have a better idea of how to turn the ring inlays to enhance this affect.
Ron in Drums PA
>Really Neat John.
I think you are right, this one would work well square.
