Vega model 1553 lathe problems
Steven Potts
>A friend of mine just bought a used vega model 1553 lathe. He says the Nova chuck that he bought will not stay on spindle while turning outboard. Says it spins off. He secures it with the provided set screw, but still no joy. Any help out there with this problem.
Re: Vega model 1553 lathe problems
Rick Allen
>Hi
Don't turn outboard (;~>)
Try reversing the lathe for outboard turning.
Screw the chuck on, then loosen the chuck 1/2 a turn. then spin the chuck like you were going to thread it 20 turns with one spin of the chuck. That will seat the chuck against the shoulder of the spindle.
If the chuck is coming free of the spindle then the shoulder/chuck insert are likely not mating well. While the deficiency could be in the chuck insert it is more likely in the spindle shoulder. You can check this with a dial indicator. You can fix this by having the spindle machined so the shoulder runs true and flat with the spindle.
Devise a draw bolt. There should be room at the center of the chuck jaws where a washer can be placed. A piece of all thread rod that will fit through the spindle is used to prevent the chuck from coming off. I would peen the chuck end of the all tread against the stop nut as well as use "locktight" on the nut. Wrap the all thread with a couple of layers of electrical tape to reduce the chance of damaging the bore of the spindle. On the inboard side run a nut and washer up the protruding all thread. You will likely find that the chuck jaws will not open and close smoothly with the draw bar tightened. So secure the work piece in the chuck before finishing tightening the nut on the inboard side of the draw bar (all thread).
Cut, sand, file or otherwise abrade a shallow recess in the spindle where the set screws hit. That slight depression in the spindle will give the set screws a lot more holding power. If the grove has a sharp grove in it this will become a break point for the spindle. The grove should be shallow, smooth and rounded.
The bottom line is that your friend is turning outboard because he is working large stock. The lathe should be run so that the spindle tightens the device that is threaded onto the spindle (reverse the rotation of the lathe).
Good Luck
Brad Vietje
Brad Vietje
>Is the chuck seating properly ?
The chuck needs to be tightened down against something -- a flat surface -- in order to hold properly. You may need a washer or shim to take up some of the spindle length for it to seat properly. These shims need to have parallel faces if you expect the chuck to run true.
Safe spinning,
Brad Vietje
Newbury, VT
