We value your privacy.
>What is the best product to use for preventing rust on the lathe bed? I've been using paste wax but it does not give the protection I need. I walked in the shop to get some tools to use on the farm last week in a dripping rain coat and found a couple of spots of rust starting where I dripped on the lathe bed. Thanks in advance for the help.
Some folks take great pains to avoid any oxidation of the bed, and attempt to keep their shiny new machine, well, shiny and new (looking). On the other hand, turners of no less stature than David Ellsworth recommend turning some fresh green Red Oak, and piling the shavings on the bed overnight, then rubbing down with steel wool and oil for a nice patina that will grip the banjo and tailstock better. John Jordan sprays his lathe bed down liberally and often with WD-40 (though I think Tri-Flow would be even better, since it won't leave a residue that dust will stick to).
For the first time in my life I have a brand-new lathe, and wonder where I'll draw the line, and what level of tool maintenance will evolve for me. Since I turn a lot of very wet green wood, I will have to expect some discoloration and oxidation. Yesterday I rough turned about 10 pieces in very wet Apple, which is another wood that will cause the bed to rust. Should I just get it over with and move on ...? I'm interested in the group's collective wisdom.
>I am also very interested in the answer to this. I have been turning a trailer load of wet green cherry which is so acidic that the lathe bed ways, the exposed tailstock spindle, the turning tools, and any unpainted brackets on my lathe rust or discolor while I am standing there at the lathe.
I use paste wax which works for about 1/2 a day and then I have slide the tailstock back and forth a few times and retract the tailstock spindle a few times and the rust shows back up.
It is not a pitting rust but rather a surface discoloration that comes off with steel wool and WD-40.
I know there is lathe maintance involved in turning and I am not trying to maintain a mirror finish, but I want to do the best I can to protect my major investment in the lathe.
I have been turning green oak the last few days and find myself frequently brushing the shavings off the ways and reapplying paste wax to my new powermatic. This seems foolish.
William Duffield over on the quiet side uses an ospho blue on all his hand tools to blue them and prevent rust. Anyone tried this on a lathe?
>On my lathes I sand away any gunk that gets left behind from wet wood and then I wipe on WD-40. On my table saw, drill press and other cast iron surfaces I use Top Cote or Dri Cote. Don't forget the bottom of the tailstock and banjo when cleaning and lubricating.
Also remember other lathe maintenance includes keeping the tool rests smooth. Use a file or sanding block. While you are turning you can use beeswax to keep the tools moving smoothly.
>I have had real good luck with a product called Break-Free oil. It is a synthetic oil that I have used on firearms for several years. I decided to try it on my lathe and other woodworking tools and have had better results with this than WD-40 or other oils.
That is interesting. I have a question in now to the makers of FP10, a product I use on firearms on using it for this purpose. They compete with Breakfree - I may have a solution at the house!
>...the logical contradiction of waxing a bedway and then wondering why the tailstock slips?? And wax is a poor rust inhibitor anyway?? I hit the oxidized areas with WD-40 and grey Scotch Btite to eliminate build-up and keep it looking like cast iron, not chrome!!
>Any water you pour on the lathe will evaporate before rust casn form. Your finishes will also dry faster, and Gorilla Glue will last for years after the seal has been broken.
>Russ - I would not know how to live without my summer sauna!!
I just got convirmation from the manufacturer that the FP-10 product should work fine on the wood lathe. He states the corrosion inhibitors should bond with the metal same as they do on firearms and prevent corrosion. A link to product site for all the others asking about this problem. I know what I'll be doing tonight!
>Spent the weekend at Ellsworth's a couple of days back in his workshop, and I'll tell you that his banjos lock up SOLID. I barely torqued the handles and I couldn't have moved the banjo with a sledgehammer.
Given the option to get better performance out of the machine with less work, why not take it? I never clean my lathe unless brushing shavings counts...
>I, too, saw the Ellesworth video where he recommends a patina. But one of the best features of my lathe, the Powermatic 3520A, is the sliding headstock feature. So there's no way I'm going to hinder it. It's fairly hard to slide it as is is -- clean and smooth. Also, I must admit, even without the sliding headstock feature, i would find it aesthetically unacceptable to let it rust. What I do when it does begin to rust, usually from damp wood shavings, is to spray on WD 40 and rub with a Scotch pad.
