can we talk about metal lathes?
Tom Sontag - St. Louis
>I have recently been salvaging some pretty cool industrial machinery bits including large cast sprockets and steel axles. Why? Um, well, as I said, they are pretty cool, so uh, maybe someday I'll use some of it. Hey, in fact, right now my coffee mug sits on a 6-7" cast iron sprocket in my office. It elevates the mug above the paper mess and is most obviously the world's coolest ten pound coaster.
Anyway, the axles might need spinning to make them different diameters or something and I find myself looking at Atlas or South Bend lathes. Clearly they have some things in common with wood lathes. Does anyone use a metal lathe for their wood turning? I presume you could rig something up in the way of a tool rest and so on. See any reason why woodturning chucks couldn't fit? Speeds seem similar. Oil pan catches chips; so what? Is this stupid to even consider trading in a 60 year old Delta for a lathe that could also turn metal?
This is mostly conversation. I have no idea whether metal will grab me in any way close to the way wood has.
Re: can we talk about metal lathes?
Doug Thompson near Cleveland
>I'll give it a try. The problem with a metal lathe is at the head stock. You are limited to hold the work with a 3 or 4 jaw chuck. A spindle might be possible but bowls would be out of the question. I own a metal lathe and thought about the same thing. The reason I never tried is hot metal chips and wood don't mix.
Keep your wood lathe and buy the metal lathe. Do you know how many tools can be made with a metal shop... it's almost as fun as turning wood.
Hope this helps a bit.
Doug
>There are several reasons. Althought you could turn wood on a metal lathe it just doesn't function as well. The cross feed gets in the way of some movements of the tool. I often use the lathe with my body or the tool very close to the bed. The catch tray that many metal lathes have would get in the way of this action. The chucks that come with metal lathes don't work very good for wood but since you have a metal lathe you could just cut threads on a rod that would fit the woodworking chucks and then chuck this up in the metal lathe chuck.
Metal lathes don't usually very high speeds so smaller items or bowls with voids would be harder to turn.
I want a metal lathe soooooo bad and in fact have a small cheapie that's really more junk that good, but I would never give up my wood lathe.
There is a metal lathe on the market that is sold as a woodworking machine. It's called the Total Shop and is made by the people that make the Smithy combination metal lathe/mill machines. It looks a lot like a shopsmith but is a lot beefier and they claim you can turn metal with it.
I would not do it.
Ray Thompson - Middletown,IN
>Metal lathes are made to use lubricated ways. Mix with wood dust and you have a greasy mess of abrasive working on the ways.
Ray
Don Evans
>I've got a Logan metal lathe, Nova 3000 and a Oneway 2436.
If you can find a Logan, grab it, but problem is people who have one don't want to part with it. The company that made them is still in business in Chicago, LoganActuator.com and you can still get parts for them, Mine is 1945 model works great.
But I don't understand the responses from all about the chuck? What makes you think a 4 jaw wood chuck like the SuperNova, Stronghold etc cannot be used on a metal lathe also.
Nova has what they call a "Z" body which is just a SuperNova with no insert and threaded for the spindle. I have one so I can use it on the metal lathe. It's threaded for 1 1/2" but I also have an insert for it so I can use it on the Nova and Oneway.
So don't use the chuck as a reason.
Have you ever seen Michael Holzapel's work, she turns on nothing but a metal lathe and makes lot of money for her work.
Concerning wood chips and the ways, any half decent metal lathe has wipers on each end of the saddle that wipes the ways just ahead of the saddle. Isn't worrying about abrasive wood chips a little far out when the machine is dealing with metal chips. The wipers are usually felt and can be added to any lathe.
As far as metal chips being hot and wood not mixing, they don't stay hot that long, by the time you change the chuck there shouldn't be any danger.
The one caveat would be NEVER run the dust collector while doing metal.
Don
Michelle Holzapfel:OUTSTANDING work on Metal lathe *LINK*
Craig Daymon
>The stuff Michelle Holzapfel does typically involves some phenominal carving as well, but I'd put her in the top 5 of people turning on a lathe and she uses a metal working lathe for all her turning. She is truly a gifted artist.
If you haven't seen her work definitely make the effort. It really is fantastic. There was a great article in Woodwork magazine a few months back (6?) that is worth picking up and includes some of her techniques for creating textures. Probably still available as a back issue.
http://www.woodwork-mag.com
-Craig
Michelle Holzapfel at Mint Museum
Issue #91 of Woodwork Magazine - see above post
Craig Daymon
>I do doubt she uses the lathe for both metal and wood, unless she does a lot of cleaning in between. Might be something about it in the article.
-Craig
>I never saw a Logan before so I glad this works. Any others that you know of with the same type spindle? Maybe a old Fay lathe might work too.
The chuck on many metal lathes are attached with a cam lock and to remove this adapter would be a pain. The spindle OD is about 2-1/2 inches so a one of a kind adapter would have to be made.
I don't worry about hot chips before I turn wood It's AFTER the wood was turned.
You have shown that a older metal lathe can be setup to turn wood but a newer metal lathe would be tough. Wood lathes are expensive but metal lathes are outrageous.
Bottom line is to find a older metal lathe with the right spindle. It could work.
Brad Vietje
Re: Issue #91 of Woodwork Magazine - see above pos *LINK*
Brad Vietje
>So far as I know, she uses an old metal lathe and turns wood exclusively on it.
There's no reason why one can't turn wood on a metal lathe, but as John points out, it isn't very convenient. Metal lathes have a lot more mass and there's a lot that gets in the way of using your hand-held tools. I use many tools with the handle held very low for a shearing cut, and found it pretty awkward to do this on a friend's metal to wood conversion lathe. There is usually a lot more width to the ways and more machine per inch of swing than woodturners will find convenient.
I did not take the original question to mean using one machine for both, but using a metal lathe for wood. It would be far better to have a dedicated machine for each, if possible. If sharing one lathe for both, I wouldn't be the least bit worried about the wood chips and dust harming the lathe (just a bother to keep clean -- that could get to be quite a mess), but far more about getting oily stuff and scratchy metal chips/spirals on my wood.
This may be a question like getting peanut butter in your chocolate, or chocolate in your peanut butter... As for bowls and woodturning chucks on a metal lathe -- sure, why not ? Those spindles are not some sort of secret code, and you can even affix a chuck to a big Morse Taper. For lathes with bayonet or D fittings, consider the VB-36, and the faceplate and chuck adapters they have made.
Anyway, if I were looking to have a wood lathe, but had an old metal lathe instead, I might sell the metal lathe to John and then I'd have the $$$ to buy a nice wood lathe !
Safe spinning,
Brad Vietje
Newbury, VT
VB-36 Info
Re: I would not do it.
Gary Evans Tallassee, TN
>Sorry Ray,
Wood dust and oil is not going to be an abrasive composition, except maybe on styrofoam.
Gary
thanks everyone
>It does not seem like replacing the wood lathe outright makes sense. Finding room for a smallish metal one would be pretty slick.
Leo Van Der Loo
Re: can we talk about metal lathes? *LINK*
Leo Van Der Loo
>Hi Tom
I do turn on a metal lathe, I also have small Delta, (10"swing) lathe to take along and turn real small stuff on.
The upside with a metal lathe is, heavy duty bearings and shaft, ways, strong tailstock, all lining up, able to make a lot of your own equipment, and having both lathes,(metal and wood )for the price of a good wood lathe, and the foot print of only one.
Here's a link to my albums, 2 have pictures of my lathe and some accessories, other have some pic's of the turnings I have made on these lathes.
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum4.html
