sanding
sanding
sanding
olejon10
>can someone tell me how to make a jig or something to sand the inside bottom of goblets and boxes i always get them just a little to deep for my fingers thanks for your help
Re: sanding
Re: Not to be flip..
>but what's wrong with a stick? You can take a reasonably heavy dowel or broomstick and attach a rotating wheel on it. Attach a piece of an old mouse pad to act as a cushion and then put on some velcro to the wheel and voila - an inexpensive sanding tool that you can stick the velcro backed sanding disks to. Alternatively you can buy one.
Re: sanding
Re: sanding
RK in Milw
>Run a search here for the Acme Sand-O-Matic. It's a simple gizmo I came up with for sanding the insides of hollow vessels and undercut bowls. You should be able to adapt it for your needs.
Ron Nelson
Re: sanding
Re: sanding
Gil Jones on Lake Seminole GA.
>This one is easy to make, and use.
Re: sanding
Re: sanding
eliot
>Check out Bruce Hoover. He makes a product called , Extend-A-Sand. It's basically just a long metal rod with a keyless chuck on the end; but this rod spins inside a long cylinder that fits over the Siux -type close quarter drill, that many of us use for power sanding. You put the usual sanding mandrel in the chuck. So it's a long power sander that doesn't wobble around much when you sand deep.
