Wood Allergy
Wood Allergy
Wood Allergy
Mark Kauder, Phenix City, AL
>For the last 6-8 weeks, I have been working with a good deal of Ebony. And unfortunately, I have found that I am allergic to it. It only manifests itself as 1) itching (some swelling) of the hands and forearms (where I get sanding dust on them (no effect on other parts of the body that get dust on - face, etc). The problem is less, if I go in every hour or so, and wash my arms well. 2) After prolonged itching and scratching, small bumps will raise and get small scabs on them (no doubt from the scratching).
I have found several remedies (one of the quickest, is some of the topical anestetic sore throat sprays). But I have to work with this stuff to finish a couple of projects, and to use up the $500+ inventory I have of it (going back to African Blackwood).
Question: Do any of you know if any of these "Liquid Glove" products would work to protect me in this instance?
Turnin' an a scratchin' down in hot Alabama.
Thanks,
Mark
Re: Wood Allergy
Re: Wood Allergy
adrien
>are you allergic to latex? why not use rubber gloves. They are also made with long cuffs covering forearms... I assume you're using a powered dust mask in addition to a dust collecotr...
Re: Wood Allergy
Re: Wood Allergy
>Thanks for the response: I am not allergic to Latex, but the "Grabbiness" of rubber/latex around a turning lathe worries me a little - though I know it would tear easily. It may be an option though.
I am wearing a mask, but not a powered filter. I plan on getting one, but don't have one now. My DC is getting about 95% of the sanding dust.
Thanks
Mark
Re: Wood Allergy
Re: Wood Allergy
GaryG in MD
>Mark,
You can use "barrier creams" -- they work by filling the pores of the skin to keep other stuff out (like grease, oil, poison ivy, or, in your case, saw dust). They will help a lot -- particularly if you also wash up and apply more cream every half hour or so. They tend to be greasy though, so you probably wouldn't want any on your hands when using tools.
There's no question that gloves can be dangerous. It's a choice we all have to make for ourselves. I'm allergic to walnut, and do use gloves -- with great care. The blue "nitrile" gloves fit a little tighter to the fingers (and for that reason may be safer), but they don't have long cuffs like the latex gloves. With nitrile, you would have to wear very long sleeves too -- and the saw dust always gets in the gap at the wrist.
I'm sure you know that allergies, particularly from "sensitizers" can get worse quickly. Your hands and arms are trying to tell you something! Best listen. ;-)
...Gary
Re: Wood Allergy
Re: Wood Allergy
Wally Dickerman in Arizona
>Mark, A number of years ago I was turning a lot of cocobolo. I developed an allery to it, as many do. I would get red, itchy areas on my body. I found that it was cumalative, that is, it would be worse every session than the time before. I tried a lot of things. Rubber gloves, painters mask, showering after turning. Nothing worked. My doctor told me that if I continued I'd end up in the hospital. I sold my remaining stock of cocobolo and haven't turned any since. Perhaps ebony isn't for you any more.
Wally
Re: Wood Allergy
Re: Wood Allergy
Carole Valentine
>Mark,
Don't know about the liquid gloves, but I started getting itching from some of the woods I was working with. I take one Claratin for Hives (non-drowsy) and it works great for me.
Re: Wood Allergy
Re: Wood Allergy
Jim Shaver Oakville, Ont.
>Hi Mark,
I had the same thing happen to me with cocbolo. I seldom turn iyt now, but when I do I wear long sleeves, tight to my wrists ( I know, be careful with long sleeves near the lathe). I use a tight collar, dust collection is also important and I do run my air cleaner too.
My hands do react a bit, I wash them well and use lotion.
Like I said I seldom turn it now, only for one of a kind applications when I need to.
Take care,
Jim
Re: Wood Allergy
Re: Wood Allergy *LINK*
Bart Rhoads
>Mark
There is a product that loggers use to prevent getting poison ivy and poison oak. It is called Tecnu. I have used it before and it does work. I dont see why it wouldnt work for your application. It prevents the oils from coming in contact with your skin. You can get it at Gemplers. The web site is; http://www.gemplers.com/a/shop/search.aspx?HKW=tecnu&UID=200606051745020784175696
Gemplers
Re: Wood Allergy
Re: Wood Allergy
John Uteck - NC
>Mark -- I've tried the liquid gloves, and they do give "some" barrier, but I didn't find that it helped as much as I would have liked when turning cocobolo. My reaction was still like a strong case of poison ivy, even after the liquid gloves. Tecnu worked well as a cleanser, and to dry the small blisters up afterwards though. Depending on how sensitive you are to ebony, the liquid gloves may give you a better barrier than I had with cocobolo.
good luck!
Re: Wood Allergy
Mark Wollschlager
>I have been using PR88 for about 6 months after a reaction to bacote.
I don't turn that anymore, but I wanted to reduce my skin exposure to other dusts.
You apply before turning dry materials or non-water based finishes.
It drys quickly to a barely noticable film.
Wash it off with water when you are done. 85-95% of the normal accumulation of crud washes off with little or no scrubbing. The rest comes off pretty easy.
The only issues I have had are that it will wear off on areas with repeated friction.
If you check the surface of a piece with the tip of your finger, eventually the pr88 film will wear off at that point. It does not flake off.
When it gets to be the hot & sweaty part of the shop year it may loose a bit of effectiveness.
They do sell a water proof version which wears off rather than washes off. When your skin exfolliates normally the stuff comes off.
I have some but have not used it yet.
Pr88 link
Re: Wood Allergy
Re: Wood Allergy
Gil Jones on Lake Seminole GA.
>Hi Mark,
If Ebony is such a problem for you, and before you chance to get it in your lungs, why not just generate an ad to trade your Ebony for someone�s African Blackwood. I have never turned either one. I drive very near you every time we go up Hwy 27 to I-185 (from near Donalsonville GA). So far I have had pretty good luck ebonizing Walnut with iron acetate.
Re: Wood Allergy
Re: Wood Allergy
OB OBrien In Pensacola
>Mark sorry to hear about the dilemma. You might want to go to a large animal vet. They have tight gloves that will go all the way up to your armpit. I have used some in the past when cleaning deer. Maybe that will help. Best of luck. OB n Sue
Re: Wood Allergy
Re: Wood Allergy
>Yeah, I think I have come to that conclusion as well.
thanks, Wally
Mark
Re: Wood Allergy
Re: Wood Allergy
Wilford Bickel
>Mark,
I was warned that one of the main ways to develop wood allergies with the exotics was to sweat while working with them - another good reason for the air conditioner in the shop window!! The oils will enter the body through the open sweat glands. I am sure you had the same 90o+ temps we did last week - were you working in an air conditioned shop? If not it might help if you could cool the area you are working in to prevent sweating. This might do more good than the creams. You are welcome to come up to Talladega County and use my shop if it would help - we'll crank the AC up on high.
Wilford
Re: Wood Allergy
Re:OB- that's just what I was.....
JamieDonaldson
>... going to recommend, but horse vets use them up to the shoulder for checking breeding mares!
Re: Wood Allergy
Breeding mares, yes...
Thad Parker
>...but on the ranch they are also used for the much less glorified job of inspecting lower GI problems...if you go this route be sure not to get their "used" gloves.
I would try an "under armor" athletic type of shirt (no loose sleeves) and the good fitting gloves previously posted about.
Re: Wood Allergy
Re: Breeding mares, yes...
Wilford Bickel
>I have a box and a half at the farm I use for Preg checking cows and AI work. As loose a fit as they are I would not want to turn in them. I have several in the trash can at the chute that Mark can have for free if he wants to try them!!
Re: Wood Allergy
Probably won't help...
>When I developed an allergy to cocobolo I tried all sorts of things. I completely covered myself with clothing, painters mask, etc. Didn't help. The last time, I broke out in hives and my doctor told me to leave cocobolo alone or I'd be in serious trouble.
Wally
