We value your privacy.
>Anyone use this stuff. I tried it right out of the (two) bottles and it was a sticky mess after two days. Truly useless. I called them and a tech rep suggested that I thin it with two parts lacquer thinner. Haven't tried it yet. Apparently, right out of the bottle it's a pure resin, which he told me is not at all suitable as a finish for a turning.
>I haven't used it as a finish but have used it as a filler for filling grooves or cracks. I've never had a problem with it hardening but have always left it overnight at least. It becomes quite viscous as it dries so I would not think it would work well for a finish on round objects. I have to build little dams to contain it when I pour it into grooves. It becomes so thin it will actually penetrate through the endgrain on some woods so you have to be careful with it.
I am planning on playing with that stuff as well as clear Inlace and cast-n-craft pretty soon so that I can write something up to descripe the differences in the 3 products and thier uses for turnings.
Someone can correct me if I'm wrong but I don't think there is an easy high build finish for woodturning. All of the finishes I'm familiar with require quite a few coats and some hand work if you want a really thick superior finish. Tru-oil is pretty good but requires about 8 to 10 coats to fill a porous wood and there is still some internal streaking that I need to see if I can solve. It is a very nice finish and almost fool proof to apply but on my initial tests it doesn't look as clear as lacquer or shellac there are some internal streaks that I was pretty darn sure I cleaned up before the last coat. More experiments are needed.
If applied properly to a well sanded wood minwax wipe on poly makes a nice finish but isn't anywhere near as thick looking as a lacquer finish if that's what your after.
>Thick films of runny coatings that take several hours to days to cure requires that the turned piece be kept in motion at a speed that is fast enough to prevent sagging and running, and slow enough that all of the finish doesn;t run uphill to the largest diameter.
You can do this on the lathe if it will run continuously at 0-60 RPM for 24-hours. Most of the new variable speed drives will not do this. Most of the older DC drives will. And that is an advantage of a DC drive that has been lost.
If you can't, or don't want to tie up the lathe, you can make a spindle that is driven by a small gearbox to rotate the piece while the finish is curing. Adjustable speed is good, but a BBR rotisserie will be the right speed for a lot of things. I have used one of these "spinners" for single-shot applications of a thick polyurethane finish on bowls, and for coating pens with an epoxy.
The biggest problem I have had with finishes that take a long time to cure is that it has to be done in a clean-room. Otherwise shop dust will contaminate the surface. I no longer have a dedicated finishing room, and that is why I no longer use any of these slow curing finishes.
>Russ is absolutely correct. I visited a shop of a gentleman who uses a 2 part epoxy finish. He has a slow speed drive that drives 4 spindles at 6 rpm. I forgot to ask if he had dust problems because he didn't have a seperate clean room to do this in.
Also epoxy is a sensitizer meaning that exposure to the fumes will eventually will eventually build a sensitivity to them so you need wear a respirator if your going to do much of that sort of thing. I do it very seldom and keep a fan at my back. I'm probably flirting with danger but that's how I do it now anyway.
>I tried it again --but thinned it considerably with lacquer finish so I was able to wipe it on easily. I don't see uneven coating, but after about 24 hours it's still quite sticky. Would a heat lamp help?
>Either Isopropyl Alcohiol or Denatured Alcohol work better as a thinner for an epoxy that lacquer thinner. I prefer the Isopropyl and use the common 70% rubbing alcohol variety.
>Russ Fairfield. Thanks you for your responses. I tried lacquer thinner because the System Three Clear Coat factory people suggested it. But I will certainly try the alcohol you have suggested. In any case, having used the lacquer thinner, I can report that now that two days have passed, the thinned-out coating is almost dry -- only a little bit sticky. I'm not sure what I have accomplished, but it's fun to try something new.
Incidentally, I purchased your three DVD finishing videos. I find them the best source of finishing instruction that I have experienced. (One of the DVD's breaks up a lot, though; if I send it back to you, can you send me a good one?)
Is an epoxy finish appropriate for non-horizontal?
Craig Daymon
>I've always thought that expoxy finishes were only appropriate for horizontal surfaces, like bar tops. Though, it certainly could be used to coat the interior of a turned vase and create a water-tight/safe interior finish. (As long as no one can see how much settles into the bottom.) I don't think System 3 will stop you from trying to use it on turnings, but it doesn't strike me as a good choice for turnings.
>They have used it as a finish on boats for years. West System is one brand that comes to mind. From what I understand, someone correct me if I'm wrong, they put a varnish over the top of it. The epoxy doesn't stand up to the UV rays very well and the varnish protects it from sun damage.
>...but I thought he used the West Systems on the sides along with a fiberglass cloth. I took it that the cloth was for strength and that the epoxy finish provided a glue component. (And served as a finish.) I think it also required a fair bit of fine grit sanding to polish the surface down level and smooth. Certainly easier on a large project like a boat.
I'm interested to hear if this can work on a turning. Also, what size turnings. I know it works great to fill voids, in assorted colors, and can be turned afterwards.
>I've used epoxy as a finish on cabinet work that needed a really waterproof finish. Top, sides, bottom, insides, outsides -- every single square inch of surface got coated. I used a marine epoxy (System Three) and applied it with a foam roller. The first coat soaked a little, especially on the end-grain. The second coat smoothed everything out. I never had any trouble with the epoxy curing when it was mixed properly and usually put the second coat on 24 hours after the first. (It self-bonds when the coats are applied within a couple of days so I didn't even have to sand between coats.)
Re: Is an epoxy finish appropriate for non-horizon *LINK*
Chuck Engstrom
>At the Renaissance Fair here in Maryland there was an outfit selling turned mugs and goblets nicely finished with what they told me was a food-grade epoxy called Plasite made by Carboline (www.carboline.com). There's a plastic out there for everything!
