I've really done it this time
Wayne Leach-NW Ontario
>After all these years you would think I would know when to keep my mouth shut???
I am just about finished remodelling the kitchen and have built all new lower drawer units throughout. The subject of drawer handles came up and after much looking without success, I was asked to make a sample up now that I have a couple of months lathe experience.
This is what we ended up with but when the wife gets my bill for $100.00 each and there are 27 in total she might have "the big one"!!!
At the speed I work, I might not be around to see the handles all on? Anyone else ever fall into this kinda trap.
Open mouth, insert foot!!!
Regards,
Wayne
Re: I've really done it this time
Gil Jones on Lake Seminole GA.
>Fricasseed foot,...hmmm...interesting.
I like the drawer pulls, sorta nautical.
27 of them will buy a PM3520 :))
Jerry Whitaker
>I think that I would go ahead and make 30 so you will have some spares if need be. Otherwise you will never get around to making any more in case of some unforseen disaster.....assuming you are like a lot of the rest of us. After 27 of them, you will be so out of it that 3 more won't matter.
>Wayne They are simple but very clean and should be quick to make. did you bore the holes through the sides before turning them?
I'm curious...
Peter Teubel
>How did you drill (turn?) the tapered holes?
>Hi John,
Nothing I do is quick anymore!!!
I completed the spindle before boring the holes. The portion that fits the hole is flat 3/8"dia and then the taper begins again? First I counterbored for the larger diameter of 1/2" to conceal the spindle joint then bored the 3/8" hole!
The sample took some time but the rest should go quicker-better anyway!
Wayne
Re: I'm curious...
>Hi Peter,
The spindle steps down from 1/2" to 3/8" where it enters the stanchion and extends the diameter of the stanchion.
The portion that fits the hole is 3/8"dia and then the taper begins again? First I counterbored for the larger diameter of 1/2" to conceal the spindle joint then bored the 3/8" hole!
Clear as mud???
Thanks for looking, now I better get to making the 2nd handle!
Regards,
Wayne
Re: I'm curious...
Bob Fawcett
>Wayne,
Did you turn the entire taper first, then turn down the spincle portion?
I like the look and admire your patience to do 27 of them.
I am in the process of turning 4 bedposts. At the rate I am able to turn, they will take me a while. Maybe I'll get faster, but now that first one is done, I have to make the others match. I only started turning in January and I still do a lot of stopping and starting and measuring to get them to look alike.
Re: I'm curious...
>Hi Bob,
I know what you meaan about measuring a lot! mI just started turning last Sept. and am having fun . I have had a lathe for 40 years and turned a few things as neede but just getting into it in earnest!
I made templates for the spindles so they will all be the same-close enough?
I stepped the handle spindle down to 3/8" dia. before I turned either taper, just worked out the details before hand. The end tasper is not exactly in the same plane as the larger taper but it is not really noticeable nor does it really matter???
Thanks for looking, I msade 4 more sets today so it is getting faster but now have second thoughts about all that same painstaking work. Only saving grace is that I am retired and the wife never pushes me and is VERY patient? Its a good thing???
Regards,
Wayne
