Toolmaking question
Toolmaking question
Steven Antonucci
Toolmaking question
steve antonucci
>I've made a bunch of tools in my lifetime, but I've never tried to harden O1. I just ordered a bunch of O1 from Enco, and I have the following questions:
1.) Enco O1 is probably not hardened (I cut it with a file...), right?
2.) Assuming I need to harden it, a torch with MAPP gas or is that too hot? What should I look for (red, yellow?)
3.) Quench in oil (since it's O1...), but does it matter what kind? I have transmission fluid, chainsaw bar oil, vegetable, mineral...
4.) The oil should smoke, but not ignite? Last thing I want is a flaming oil slick in my driveway.
5.) If the shank of the tool is O1, it probably makes sense to only harden the tip, and not the full length, right?
Steve
Can you tell I bought a torch last night? :-)
Re: Toolmaking question
Re: Toolmaking question *LINK*
Bob Fawcett
>There is heat treating info on this site
Knifemaking site
>Steve right on all your questions. When you quench it plunge it completely in the oil. This reduces the chance of fire. I use peanut oil because it's easy to dispose of and has a higher flash point however anything will work. I'm sure there is a very specific way to do it if you want the best results but at home with a MAPP gas torch we probably can't do it perfectly anyway so whatever oil you have is good.
I do only heat the first few inches and leave the tang unhardened. It's easy enough to reharden the tip once you've ground past the hardened area. Old timers used to do this on thier carbon steel tools all the time.
I treat 01 pretty much like w1 except for the quenching material. If you want specifics, when you order the drill rod ask for the hardening specs and they can send you sheet that will give you all the temperatures and procedures for a certain hardness.
safety
>I forgot to mention. I keep a fireproof lid handy for the quenching vessel, do it outside and keep the fire extinguisher handy. I've never had a fire but I'm real nervous about sticking a red hot piece of metal in oil so I take precautions just in case.
Phil Joines Krum, Texas
Shouldn�t be unless you ordered it prehardened. If it cuts with a file it's soft.
MAPP is fine up to about �� diameter. Use a magnet, when the magnet won�t stick the temps right.
Temper in the oven at 400-450 degrees for an hour. You can do it be color but it�s harder to do.
A lot of people use olive oil because of it�s high ignition temp. Actually, water will work just fine. It makes it a bit more brittle but that�s removed when you temper it. You need enough to quickly cool the metal. For say, the tip of a �� hollowing tool at least a pint and if it gets hot wait for it to cool down before doing another.
See #3.
Yes
Russ Fairfield
>The article that I have here on Wood Central might be helpful.
Making Our Own Turning Tools
Peek in here *LINK*
>Steve,
I did post this not too long ago, hope it helps.
Jorge
http://www.woodcentral.com/cgi-bin/turning.pl?nofr
