Bowl turners & Jet 1642 lathes
Pete in Holland, MI
>Guys -
Starting to salivate over the Jet 1642EVS lathe. Wanting to upgrade my Jet 1236. Have scanned over the archives and everyone seems to be happy with the machine. Have a few questions for you users out there:
1) Are you 1.5hp owners happy with your choice, or should you have spent more for the 2hp unit?
2) At approximately what rpm in low range does the machine's spinde power fall off to where large diamter turning would be tough?
3) Any problems with the speed controller or motor that I should be aware of?
4) Any great deals or dealers out there on these machines (other than Amazon's current $1700-ish price) ?
5) Will a trade show price be better than Amazon's prices?
Many thanx.......
Pete
Re: Bowl turners & Jet 1642 lathes
>Be sure and check the price at www.toolnut.com. I bought my powermatic from them and so did most of my friends and it's a good company to deal with and usually the lowest price.
Can't answer your other questions. My powermatic has huge amounts of torque at very low rpm (Idon't know the speed for sure but I'd say it goes down to about 60rpm before it stops and it still has torque at this speed.)
Rick in Colgate, Wi
>Pete,
Have you considered moving up to a Powermatic 3520? I have a Delta 1642 and wish I had a larger swing and plan on upgrading to the Powermatic sometime soon.
Re:Reconsider the upgrade..
JamieDonaldson
>... because you are not gaining much- from 12" to 16" swing for a bowl lathe is not much, and you probably will regret that you didn't go for the increased capacity. Invest the money in a lathe with substantially larger capacity like the Powermatic 3520 series, even if it means having to expend a few more dollars in the long run.
robo hippy
>If you want the 2 hp motor, get the PM3520, which is what I have. I don't turn too many bowls or platters over 16 inches, I like the extra room just in case. The lathe will keep its torque down to the lowest speeds.
robo hippy
>Speaking as a 1642 EVS owner.
If you are primarily interested in turning bowls, do consider the Powermatic 3520.
If you are primarily interested in turning bowls and still want the 1642 EVS, consider the 2 hp option.
I got mine (1.5 hp) for primarily turning spindles and then the very occasional bowl.
Speed control box - does not play well with GFI circuits. Unplug it during thunderstorms.
I bought mine at a show from a local dealer, so I got a discount. But the price was similar to Amazon's.
The low end of power? Switch the belt position to the low range. Gives you plenty of torque down there.
My $0.02. YMMV.
Elvin Bryant
>I have the Jet 1642 and I regularly turn bowls greater than 16" by sliding the headstock to the end and using an outboard tool rest. I have the 1 1/2 hp model which is adequate but I wish I had bought the 2 hp model. Overall it's a fine tool.
Bob Fawcett
>I bought the Powermatic 3520B. The short bed extension on this lathe can be mounted to the leg and this adds about 9" of swing on the outboard position for a total of about 38". It may be possible to do something like this with the jet. They make a 20" bed extension for the lathe. You would have to drill and tap the leg to mount it low. On the powermatic, there is a tool post extension to bring the rest back up to center. You may be able to adapt the powermatic, or you could creat one.
I agree with the rest of the posters above, spend a few more dollars and buy the PM.
Long time user of a JWL-1642 (long)
Dominic Greco in Richboro PA
>Pete,
I think I was one of the first people to own one of these lathes. I bought mine shortly after they came out on the market. I wrote a review of it for Wood Central and since that time have gotten dozens of letters telling me how satisfied others were with their purchase of a Jet JWL-1642EVS.
You asked:
"Are you 1.5hp owners happy with your choice, or should you have spent more for the 2hp unit?
I really like the 1 1 /2 HP version I have. That being said, I wouldn't have minded the extra 1/2 HP. If I had more money (and time to wait) I might have gone that route. But I only had enough for the 1 1/2 HP unit and I've been happy with it ever since.
From what I've been hearing, the price for the 2HP unit has gone down since it first came on the market. I'm sure someone on this site knows somewhere out there that is offering the 2HP unit for under $1800
You asked:
"At approximately what rpm in low range does the machine's spinde power fall off to where large diamter turning would be tough?"
Thats a tough question. I've turned some pretty big bowls and hollow forms with my lathe. As long as I use a sharp gouge, I've never had any problems with power falling off at the lower RPMs I routinely turn big, out of round blanks at 200-300 RPM with no problems. Then again, I learned not to try to take huge bites, and to have a sharp gouge. I've attached a picture of a big walnut bowl I was turning to illustrate the point.
You asked:
"Any problems with the speed controller or motor that I should be aware of?"
None that I'm aware of. It's worked perfectly for me for almost 4 years.
You asked:
"Any great deals or dealers out there on these machines (other than Amazon's current $1700-ish price)?"
I seem to remember the name "Toolnut" as some place that offers a great deal on thse lathes. Other than that, I really can't help you. But I'm sure others here will weigh in with a name and a place. They're great that way!
You asked:
"Will a trade show price be better than Amazon's prices?"
Possibly. The people in the booth tend to bargain on the last day of the show. They'd rather sell the equipment than have to pack it up. But that takes patience and having the cash on hand.
Now, I've noticed a a lot of people advising you to just spend the extra dough and go for the Powermatic 3520B. If you have the extra cash, I'd have to agree.
However, if you're in the same boat I was in when I upgraded from a Jet JWL-1236 (same as you are now), I had a limited amount of cash I could work with. While I would have loved to get a bigger, badder lathe, I just couldn't do it. My advise, buy the best lathe for the amount you can afford. At the time, the Jet was in line with my budget.
Bottom line; Am I happy with my Jet JWL-1642 lathe? Damn straight! Does it fit with the projects I like to work on? I can turn pens, bottle stoppers, and small boxes. Then the next night I can be working on a big deep salad bowl. Just about every thing I've wanted to try, this lathe has handled without a complaint.
If you do go with the Jet, be sure to read my article on adding a ballast box and trestle legs. They really (and I mean REALLY) were one of the best accessories I could have added to my lathe.
See ya around,
Dominic
Re: Long time user of a JWL-1642 (long)
>Dominic,
I'm way behind you on this one. I still turn on a 1236, but also plan to upgrade to a 1642 sometime later this year.
I appreciate the advise you provide in your well written and clearly illustrated article. It is one important factor that led me to choose the 1642 as my "upgrade path."
I notice, however, that your sandbox has the same problem as the sandbox on my 1236. Its flat and level top collects shavings. It seems to me that a sloped roof, that dumped the shavings out onto the floor in front of the lathe, would work a bit better when it came time to turn on the shopvac and clean up the shavings. I haven't used one of the tool baskets that this lathe comes equipped with. Do you think it would adversely affect the utility of the tool basket if it could not be swung back beyond the position shown in your photos, because it collided with the peak of the sandbox roof? I realize that none of your photos show the basket in use, and thus you may not use it, and may not have a gooc answer to this question.
Jet 1642 lathes - Try Equipment Sales And Surplus *LINK*
Craig Daymon
>I'm pretty sure this is where I bought my 3520A about a year back.
They have the 1642 in both the 1.5HP ($1699.99) and 2HP ($1869.99) models with FREE shipping. They also have the Powermatic 3520B for $2649.99, again free shipping. They have some of the accessories as well for what looks like reasonable prices.
The also have an Oliver 10" Jointer with optional spiral cutter head on special. Not an easy shop add-on, but looks like quite a machine.
Anyway, someplace else to compare pricing. I'll put the link below.
-Craig
Equipment Sales and Surplus
>William,
Thank you for the compliments! And good luck with your eventual upgrade. I'm sure you'll have a blast with the new lathe.
You wrote:
"I notice, however, that your sandbox has the same problem as the sandbox on my 1236. Its flat and level top collects shavings. It seems to me that a sloped roof, that dumped the shavings out onto the floor in front of the lathe, would work a bit better when it came time to turn on the shopvac and clean up the shavings. I haven't used one of the tool baskets that this lathe comes equipped with. Do you think it would adversely affect the utility of the tool basket if it could not be swung back beyond the position shown in your photos, because it collided with the peak of the sandbox roof? I realize that none of your photos show the basket in use, and thus you may not use it, and may not have a good answer to this question."
As the article suggests, I designed the ballast box to allow the supplied tool basket to be used. As far as it's usefulness, it's not the greatest accessory I've ever seen. While I have used it occasionally to hold various accessories like a knock out bar, long gouges, and face plates, it's location makes it useless for anything other than a chip collector. It's so annoying that I'm going to remove it one of these days. When I get around to it.....
My initial idea was to design a box with a sloped lid. But I'd need a slope of 45 degrees. The angle of repose for wood chips (the lowest sloped angle at which a granular material will begin to slide)is 45 degrees. Before upgrading to my 1642, I enclosed the sides of my old Jet 1236's stand with just this in mind.
So I had a nice design problem. I needed to store (6) 50 lb bags of sand (300 lbs). I also didn't want to extend out past the outline of the cast iron legs. I wanted minimal interference from obstructions while turning. That gave me my maximum width. Due to interference issues with the cast ribs on the legs, sloping the lid to 45 degrees complicated the design somewhat, and made the box's lid difficult to remove. Therefore the height of the box was limited. Since I also wanted access to the sand bags, the lid must be easily removed. If I ever need to move the lathe, removing the sand bags will make that job much easier.
One nice side effect of the flat topped box is the convienient shelf that now holds my vacuum chucking system, and an air hose from my compressor. In addition, designing the box to feature a flat top, allowed for a gap between the top of the box, and the bottom of the bed. This space makes it easy to get my hands under and around the bed/ways. This makes attaching various accessories like my steady/bowl rest easy.
See ya around,
Dominic
dick mc neill
>I had a Jet 14-42 for a few months but the machine had some minor drawbacks. I realized I should have bought the 16-42 & did so eight months ago. It is a good lathe. There are two torque settings for speed. I've never used the slower one because I've turned heavy 15 inch pieces with no trouble. I've used the Kelton core saver often with the 1.5 HP motor with no stalling. Never had any trouble w/ speed control or vs motor, I bought mine on sale from Woodcraft mail order, $1600 for the lathe & $ 35 for lift gate delivery to my home.I've bought a lot of machinery from Amazon & have never had a problem (I always wait for the free delivery specials). One thing:Jet advertise a 3 inch faceplate but always send a six inch one instead. Be advised.
