This will dampen your spirit
Doug Thompson near Cleveland
>Last night I sprayed the last coat of lacquer on three hats. Needless to say the weather has been very humid the past few days and guess what happened. Yep, all three cloudy as can be.
A fast sanding and a quick spray... delivered at 4pm. The finish wasn't good to say the least. The hats are for some guys that have wooden cars in a show this weekend. This is one time I was glad I never accept money for any woodworking project.
Did you ever have a last minute mistake ruin your work?
The picture looks OK but not up close.
Re: This will dampen your spirit
Pete in Holland, MI
>Was the customer expecting clear? Would he really care or notice? How bout the aliby that this is something new that your were trying? You have a lot of work in these hats. I would possibly reduce the fee, but not give them away. Giving them away is a self imposed "punishment" to yourself for what happened to the finish, but a bonus to the recipient of the hats. You lose. He wins. If they're that bad, smash them. If they are tolerable, put your salesman's hat on and sell the blemish as a highlight.
My thoughts.....
Gil Jones on Lake Seminole GA.
>Doug, I doubt that the wood is hurt. Lacquer is easy to remove with lacquer thinner, and start over.
Keith Tompkins
Keith Tompkins
>Doug, don't panic yet....the white may disappear over time, or by placing the hats in a dry, hot room. An additional coat with retarder added MAY help.
I haven't done that.
Dave Smith, Longview, WA
>Of course I have never turned any hats to screw up the finish. You might want to try Rockler's gel polyurethane. It is very durable and the satin finish does not show finger prints. Sand to 600 and between coats. Rub it in wipe off excess, recoat in as little as 4 hours. Two coats is all you will need in most cases. It is my finish of choice if I am not after a gloss finish.
Great looking hats from my vantage point. If they are free my hat size is 6 7/8.
Dave Smith
Batter up in Longview, WA.
Easy Fix
Joel Hunnicutt
>Load lacquer thinner in your gun and mist LIGHT coats of thinner. This will soften the lacquer and let the moisture out. You may need to do this a couple of times.
>My pride was hurt more than anything. To give your work away when it's not your best is embarassing. Not that it has to perfect but better than this. It was a rush job to make three hats before the car show so time didn't allow for any mistakes. I'll sand the finish down next week when they return from the show and they should be fine.
I never thought of using thinner to let the moisture out... That would have done it. Oh well :(
My normal finishing starts with M.L. Campbells vinyl sanding sealer followed by their dull lacquer. It's easy to use and protects the hat from rain.
I'll bring some to the symposium.
Thanks, I feel better today.
Doug
Stephen Mushinski
>Same thing with the cloudy finish happened to me a few years ago. I took sprayed pieces from a warm building out to my truck. It was cold and snowing. The next day I looked, and it seems cloudy. As days passed it just kepted getting worse. I fixed it by taking the finish back down to the wood and reappling a finish. - Lesson learned - Do not take uncured finishes out into the cold! - Steve
