round bottom bowl...critiques welcomed
LT
>my first attempt at a round bottom bowl...spalted maple, 7 1/2 by 2 1/2...watco, waxed and buffed...critques welcomed
LT
Re: round bottom bowl...critiques welcomed
Brad Vietje
>Hey LT,
Looks like a real nice bowl from here.
The wood is beautiful, the form is very nice, and the profile seems nice and smooth, without obvious flat spots, or changes in curvature, and the finish looks great ! Did you turn a small flat or depression for a foot ? I would only like to see the junction between the main body and the rim a little more distinct -- it looks a little rounded over, possibly from sanding ? You could also experiment with a slight curve to the top rim, with a little cant inward or outward.
Safe spinning,
Brad Vietje
Newbury, VT
LT
>Thanks, Brad...ever since I started shear scraping "the Ellsworth way" (from the video), it's made a huge difference in the quality of the wood surface.
I did not turn a depression on the bottom...the bowl definately wobbles and spins. You are corrrect about the rim. Over zealous sanding caused the crispness to disappear. I'll try your suggestion about the curve at the top of the rim.
LT
