Saving Cedar
Saving Cedar
Saving Cedar
Thad Parker
>I turned this while on vacation at my in-laws, only my second turning. My father-in-law owns the lathe, but is actually more inexperienced than I am and insisted on running all-thread through the center for safety; thus I had to plug a whole in the center. He also insists that this cedar will "bleach out" and lose it's luster turning brown & tan instead of staying the red & yellow it is now. Is this true, and is there any way of finishing this piece food safe so that it maintains its color?
Re: Saving Cedar
Re: Saving Cedar
>It will gradually turn tan instead of red. Not much you can do about it. You can use UV inhibitor finishes such as Spar Varnish but it only extends the period before it changes. Keep it out of direct sun and it will last awhile. I cringed when I read the althread part.
Re: Saving Cedar
Re: Saving Cedar
Thad Parker
>I am still a little bitter about the allthread myself. When I agreed to allow it, I misunderstood him thinking the whole would only go into the base...but no...he drilled a hole all the way through my fruit bowl!! I am thinking of buying him an expanding chuck for Father's Day so that I can turn things the way I want to next time I visit.
Re: Saving Cedar
Re: Saving Cedar
>The good thing about a chuck is that it has a hole through it to accommodate the all-thread rod. Just kidding.....Well, maybe not?
I am baffled. Please 'splain' this to me. He ran an all thread rod all the way through it and did what? Ran it back through the shaft in the head stock and put a nut on it as if it were a "draw bar"? Was there a face plate involved?
If this is the case, I don't think a chuck will help. He must be very frightened of stuff flying off the lathe. Maybe an excellent face shield/catcher's mask and perhaps a chest protector. A dose of confidence would help also.
Nice piece of work on the fruit bowl.
Re: Saving Cedar
Re: Saving Cedar
OB OBrien In Pensacola
>Hey Thad; How about directing him to a nearby AAW chapter for lessons or buy him the "Fundamentals of woodturning", book.
Re: Saving Cedar
Re: Saving Cedar
Thad Parker
>Yeah, it was really obscure to me too. There was a faceplate screwed to the base, but he claimed that since the cedar was "so soft" the screws would pull out while turning. There was a nut on the back side of the headstock and the allthread running through the headstock, through the faceplate, THROUGH the bowl, with another nut keeping in from flying off IF the screws failed, which they didn't...but that's probably because he replaced my woodscrews with 3" lags, keeping me from being able to turn the pedestal down like I had wanted to. So all this inconvenience on my vacation project and it still turned out to be presentable, I cannot complain too much, but I'm glad to offer amusement for the rest of you who have the blessing of turning In-Law free.
Re: Saving Cedar
Brad Vietje
Re: Saving Cedar
Brad Vietje
>Well, Thad, it sure looks nice, despite your father in law's efforts !
On the bright side, you can chuck it correctly, or even work with a faceplate on your next bowl, and get the look you want without the $#*%$@* hole in the center ! If you ever get a chance to re-mount this one, you could turn a small, flat-bottomed rabbet at center, and glue in either a little disk of Red Cedar, or a contrasting wood like Ebony. This could either be turned and polished before gluing in, or glued in, and turned to mate with the bottom you already have.
You F-I-L would be amazed to see bowls turned with a simple friction chuck, as is shown in Keith Rowley's book, Woodturning: A Foundation Course. This is just a very slightly tapered short tenon jammed into a corresponding tight-fitting hole in a waste block -- you need a little flat ring surrounding the tenon for best results, but not even a single screw !
My dad, who passed away just over 2 years ago, had all sorts of these turning fears that probably came from learning to turn in shop class in the 1940's with dull tools and techniques that said more about not taking risks than getting good results. Once he learned that the tool handles did not have to be parallel to the floor, and a little about newer tool shapes & bevels, and how to get his tools much sharper, his turning advanced very quickly. If we could only count the number of people who were turned off to turning by either bad instruction or a fear of injury in shop class, we'd have a really large number !
Safe spinning,
Brad Vietje
Newbury, VT
Re: Saving Cedar
Re: Saving Cedar
>Thanks, Thad.
I suspect your FIL has too much deeply rooted fear to ever be comfortable turning. OTOH, he must think a lot of you, or he would have given you a few short dull screws for the face plate and told his daughter to increase your life insurance.
It is amazing what you learn here. The other day someone pointed out you could have two lathes "back to back" with the head stock on one and the tail stock on the other and turn something as long as you could manage. I would have never thought of that, but I will file it away under something that might be useful someday.
I would never have thought of mounting a piece with a draw bar, but I will file that away too. Maybe someday I'll.....
Re: Saving Cedar
ebd
Re: Saving Cedar
ebd
>Thad,
Instead of buying a chuck for him put your money into a mini lathe for yourself. Then you can turn whatever & however you want.
Larry
