RIDGID Bandsaw Riser Block??????
Greg H. from Wisconsin
>I have a 14" RIDGID bandsaw, the casting looks the same as a Jet or Delta. Would either a Jet Or Delta's riser block kits fit this saw. Has anyone done this before or have you found the RIDGID riser kits. I'm a bowlturner, I would like to think so at least, and the 6" limit is fine but I would be nice to have a 6 1/2" bowl blank go through the saw without a chisel or chainsawing it again.
Thanks
Greg
Re: RIDGID Bandsaw Riser Block??????
>The very similar castings, and the even more similar riser blocks themselves, are but a small part of the equation. There are also two blade guards, and the column that supports the upper blade guides. The Delta, JET and Powermatic 14" bandsaw riser block kits are not interchangeable, even though JET and PM are owned by the same company, in part because the upper blade guides are different, and the column raising and lowering mechanisms are different. There is no reason to expect that the Ridgid mechanisms would be interchangeable with any one of these other brands, but they might be.
A warning: If you happen to find one that is partly compatible, please do not skimp on safety if you cannot lower the upper guide blocks for minimum clearance above your work, or if the blade does not remain completely guarded. I was talking with a guy just today with a missing thumb, due to an improperly adjusted and guarded set of upper bandsaw guide blocks. (Not a Delta, RIDGID, JET or PM, but the accident was not brand related.). He lost it this winter, after over forty years of woodworking.
Bill Kay
>I'm using the Ridgid riser block on my Jet and it works great. Everything in the kit fit as designed. I think the only real difference is the color of the paint.
>Where did you find the riser block for the ridgid??? I can't find one.
thanks
Greg
>Never mind, I found them at ridgidparts.com. NOT cheap either. But its what I need.
Thanks
Greg
Bill Kay
>I found mine at HD about 3 years ago. They had the riser kits on "Close Out" for 15 bucks. It looked like it would work so I went for it.
A friend had a Ridgid 14 inch saw so I figured if it wouldnt work on mine I could give it to him.
Robert Grady
>The riser block for the Grizzly 14" band saw is a perfect fit. That is what I put on my ridgid saw and it sells for under 60.00
A
>I installed a Jet riser block kit on my ridgid band saw and it as though the two companies are one and the same. The fit was perfect right up to the last screw.
Walter Ahlgrim
>Does the blade guard work? Will it cover the blade all the way down to the table?
>The manufacturer of the castings is probably the same. Even if not, it's easy enough for one manufacturer to replicate the castings, and the sheet metal stampings, nuts and bolts, etc., as well. That does not necessisarily mean the same "company" (your importer and distributor, and your provider of quality control, warranty, customer service, user's manuals, parts lists, parts, accessories, etc.) is the same.
If something goes wrong, you will have to call the "company". If you are dealing with two "companies", which one will support your particular problem? For sure, you will not get any help from the manufacturer. You will not even be able to find out his name, and even if you had his name and address, it wouldn't be written in Roman characters, except maybe the telephone number. If you called him on the phone, the chance that you would be able to even talk to someone who could speak English is slim to none.
It's good to know that, in this particular case, all the parts are compatible.
There's really not much that can go seriously wrong with a riser block kit, assuming the manufacturer uses a little common sense, and uses reasonable care to insure that the top and bottom faces of the block itself are machined flat and parallel. There are a lot of ways they still can be incompatible, however, even if the castings are identical.
This is still a good question to ask, and to be answered, at least in part.
Trying to fill out a complete compatibility matrix among all the name brands using the plethora of Taiwanese and Mainland Chinese foundries, however, would be a daunting task. For sure, the name brands alone would not be sufficient. A serial number might help. The "company" often changes manufacturers. Regrettably, the "company" also all too often changes ownership and management and even corporate philosophy. There are a few I trust, some I trust about as far as I can throw a riser block kit, and some I trust about as far as I can throw a 14" bandsaw.
