steadyrests
steadyrests
steadyrests
dwfII
>Thank to everyone who responded on the question of collars. Every little bit helps...
Wally,
That seems to be a problem with Jet minis...you can't find a steadyrest that one) fits the 1014, two) is reasonably priced, and three) doesn't rob too much clearance from under the vessel. At eight inches in diameter on this maple HF, I am working almost at the limits of the machine when you consider how much space the banjo takes up. Oh, for a Vicmarc 200 shortbed! [sigh]
Tight Stitches
DWFII--Member HCC
Re: steadyrests
Re: steadyrests *LINK*
Phil Joines Krum, Texas
>Vessel steady's aren't hard to make. I got 10 hits searching the Articles for "steady rest". This link is to Dominic Greco's steady. Just size it for the mini.
http://www.woodcentral.com/articles/turning/articles_128.shtml
Re: steadyrests
Re: steadyrests
dwfII
>Phil,
Thanks...I've seen that. It's a good link and and looks to be a great steadyrest. But, same problem...too much swing lost to the mount. On a Jet 1014, I just don't have any swing I can afford to lose.
Beyond that I don't have a bandsaw [sad]--shop is too small--and have never been happy with the results when I try to fabricate something like this with a jigsaw and clawhammer. [grin]
DW
In the High Desert of Central Oregon
Re: steadyrests
Rick Allen
>Here is a steady rest that will solve two of your three problems. It will fit your lathe and you won't lose much swing.
Steady rest
Re: steadyrests
Re: steadyrests
dwfII
>Rick,
Isn't the Clark about the best steadyrest you've ever seen?! I contacted him about six - eight months ago. But unfortunately, the price is way out of my league. I think having seen that rest, however, it formed my opinion of what is needed, especially for the 1014. Gee, I wish I could afford it.
DW
Re: steadyrests
Re: steadyrests
>You can make is square and design it so that it will clamp on the sides. somewhere on the web there is a steady that uses All-thread rod for the sides, has a flat board on top with 2 wheels and one board on the bottom with 1 wheel. This would be an option. Hope someone can help you with this. I'll be working until well after dark and won't be home where I can look it up.
Re: steadyrests
>I found this by doing a google search. Gotta run to an assignment but do a search on Steady Rests and you will find a bunch of things.
http://www.hdv.net/tips/Making%20a%20Steady%20Rest.htm
Re: steadyrests
There is a message here for lathe buyers
Bill Howatt
>I don't want to knock this thread askew but people contemplating a lathe purchase should pay attention to your plight.
There is more to considering the swing as "the maximum diameter" piece that can be turned. It is nice to have extra space for specialized tools like steady-rests and being able to easily move the banjo anywhere.
Naturally, this is just one of the factors that has to be considered along with space and budget and...
Bill
Re: steadyrests
Re: steadyrests
>Check out Mark Kauder's comments under "collars" down below and you will see a steady for the jet mini.
Re: steadyrests
Get thee to the wet side of the mountains
Dave Smith, Longview, WA
>I was hoping someone would give you a good plan for what you need so I wouldn't design one. I have my Jet mini set up for turning pens. John Lucus already mentioned what I had in mind. It can be square and it can be clamped on the side to eliminate any interference above the ways. If you need something cut into a circle let me know. Shipping ain't much considering the raise in elevation from here too there.
Dave Smith
Thanks to WC I have a lot of friends I have never met in Longview, WA.
Re: steadyrests
Re: steady rests Partial hijack.
>I was thinking of a steady rest also. I like Mark Kauder's design. What I had thought of was a square with a wheel coming out of each corner. Seems to me that the square would only have to have an inside dimension slightly larger than the swing of the lathe, because the wheels could retract into the corners of the square. The more I think of it it seems the steady should have three sides of the square with the bottom side missing so the banjo could slide under it. Could be mounted under the shaft out of the way. Maybe I'm over-thinking this. If the bowl were almost touching the ways, it would be in the way of the banjo. Anyway, I've been cogitating and ruminating on this a while. I like Marks design, but it seems to me there should be a wheel at about 9 o'clock, where the chisel does its work. Or does that not matter? Just how sturdy do these have to be? Is slight pressure from the wheels enough to dampen the chatter, or does it have to be stronger than that? Can the wheels come up at an angle, as from the base of the bowl toward the rim? That would get the frame back behind the rim of the bowl and out of the way. What are the best wheels to use? If I get wound up on this I might make you one for the cost of materials and shipping. Like I need something else to do.
Re: steadyrests
dwfII
>Barry,
Well, that would be both generous and...outstanding! I have thought about having a metal fabrication shop make one but I'd have to draw up some designs and not ever having used a steadyrest (although I surely could have used one on my apple vase...posted here some time ago...it would have tamed my Kelton tools, I think) I wouldn't really know what problems in the design to anticipate and/or how to avoid mechanical problems I didn't anticipate. In the end I might have to design and have made several models before I got it right. I think...given that I'm still a bootmaker full time...I might lose interest or run out of patience if not money before I could get anything to fruition.
The main thing is that I'm a frustrated Vicmarc 200 man...IOW, I want to do bigger stuff and end up pushing my poor Jet to its limits. If I could do nine and one half in diameter vessels on it I would. Eight inches is getting there, though.
Anyway...even if nothing comes of it, I thank you for the offer/thought.
DW
Re: steadyrests
Re: steadyrests
>Something else dawned on me on the way home from work. On something the size of a mini lathe you don't even need to mount it on the lathe. Put the lathe on a 2x10 and mount the steady rest to that. You could move the lathe up and down the 2x10 to get the steady in the right place. If need be clamp the lathe to the 2x10. Actually on that lathe a 2x8 might work.
