Bill Crommett made a big mess O.T.
Bill Crommett
>I made a tricycle out of some old bike parts and today I started to Bondo over the rough parts. I mixed up a batch of green stuff with some activator that was in the drawer and after applying about 1/2 cup of the stuff to the joints I wonderd why it wasn't kicking over. So I read the small print on the activator tube ---- which turned out to be DISK CEMENT activator. BIG MESS Does anyone out there know what will disolve or dilute the stuff I can't scrape off ? With the vast experience of this group, one of you must have lived long enough to have goofed on a similar matter. HELP
Bill
Re: Bill Crommett made a big mess O.T.
Bob Fawcett
>Not sure about your mess, but at work we use MEK to clean just about anything but mostly aircraft sealer. It will disolve most things.
I have never tried to buy it, but seems like a paint store might have it. MEK stands for methyl ethyl ketone.
eaglesc
>The local Lowes carries MEK.I have never used it, I Stick with acetone but I kow my Lowes has it.
adrien
>CAVEAT:
Methyl Eethyl Ketone becomed carbon MONoxide in your system when you inhale the fumes. If you use it, do so in well ventilated areas.
Gil Jones on Lake Seminole GA.
>Lacquer thinner, safety glasses, protective gloves, and good ventilation.
Lowes sells epoxy stripper
Brian Simmons, Heflin, AL
>Lowes has an epoxy stripper that is in a quart can and is a golden color. I think it was about $10. I used it to strip some poured table top epoxy finish that I did not like. Did a great job on the really hard cured stuff. Should work as well removing your oops.
