revelations of the inexperienced
Mike Hamilton
>Old news to most, I'm sure. Revelations to me, none the less. Hopefuly valuable to other neophytes.
Garage is shop. Thorough cleanup required after use. Wood taking too much space. All added up to an afternoon at the lathe and bandsaw. I managed to rough four bowls and subdivide another four cracked half-logs into smaller squares. Wood was more dry than green so turning was a bit slow.
These are my lessons learned:
If you wonder if the tool needs sharpening -- it does.
Frequently tighten the tailstock, you might lack purchase, rather than power.
Go faster sooner. Starting slow is fine for out of balance but the cut is smoother at speed. Practice makes perfect (at least better). You do develop muscle memory.
All in all, a fun afternoon. And a lot was accomplished with only one cleanup seesion.
Regards,
Mike Hamilton
Plainfield, IN
Re: revelations of the inexperienced
Jim Shaver Oakville, Ont.
>Sounds Like a perfect All Around Day Mike!!
Take care,
Jim
Jennifer@Indy.USA
>Bravo Mike!
Glad to hear you got a solid shop day in...what a way to spend this beautiful day we had. Turning away...listening to the race, the smell of fresh cut grass in the air...
Perfect!
Jen
Doug Thompson near Cleveland
>Revelations are wonderful because it shows you learned what was taught.
To have a great day in the shop... priceless...
Re: and one I forgot
Mike Hamilton
>.... turning off-handed is worth the effort to learn. Lots easier than drawing a pull cut end to end with this body in the way!
Mike
