Maple Lidded Box
Chris DiCiaccio
>Another box is born. Still trying to get the hang of the end grain hollowing with the sorby. Also used a 1/2" scraper. The scraper cut much better than the sorby. I'm not sure why it's not cutting right.
Maple Lidded Box
Chris DiCiaccio
Re: Maple Lidded Box
Chris DiCiaccio
>Chris They are looking good. How are you using the sorby gouge. I use mine with going from center to rim with the flute pointing about 9 oclock. I rotate the gouge so the top wing of the flute is just 2 or 3 mm away from the wall, cutting with the bottom wing. I should say I use a grind similar to the Ellsworth grind.
John,
Chris DiCiaccio
>Well, I'm not using a gouge, I'm using the Sorby Hollowmaster and also the sorby midi Hollowmaster. Neither seem to cut shavings. This is interesting about using a gouge. I have an irish grind bowl gouge. Can it be used on end grain?
Re: John,
>I've never known exactly what an Irish grind is but I thought it was similar or maybe even the same thing as the Ellsworth grind. I think any grind would probably work because I've used the Stewart Batty grind to hollow a box but it was trick, your too close to the corners of the cutting edge. A swept back grind where the wings are ground back gives you plenty of clearance and works well for me.
You might try grinding your scrapers to a sharper angle. I used to keep my scraping cutters rather blunt at about 75 or 80 degrees thinking it would hold an edge better. It might, but I find I grind them all between 45 and 60 now. They don't hold an edge that well but give great shavings. My hollowing scrapers are closer to 60 because I'm just wasting away wood and you won't see the inside of the vessel anyway so I'm not concerned with the cut. My box hollowing round nose scrapers are about 50 degrees now but I'm creeping them toward 45 each time I sharpen.
Re: John,
Phil Joines Krum, Texas
>John,
The Irish grind has longer wings, about 1" long. Other wise it's the same as David's.
Re: John, *LINK*
>Chris,
I start by drilling a hole to within 1/8" of the depth of the hollow using a taper shank drill. Then use the hollower to cut from the center out with the tip at center, tilted down just a bit. Sharpen the bit with a diamond hone stroking toward the cutting edge or on a fine grit wheel. These tips get dull faster than you'd think.
BTW to keep the drill from spinning I drill a 9/32" hole through the shank and insert a 1/4" rod. Vise Grips will work too. The 25/32" is the largest made with a #2MT shank.
25/32" taper shank drill
