Bummer!!!
Bummer!!!
Bummer!!!
Ron in Drums PA
>During last nite's storm, one of the bigger big black cherry trees that is on our property fell. I've been eyeing this tree and thinking about cutting it down this fall.
It couldn't have landed in a better spot. Totally missed our garden with easy access all around, I couldn't have planned it better myself.
So why is this a bummer you may ask?
Re: Bummer!!!
I know (hand raised)
keith zimmerman, Normal IL
>Because now you have to cut it up, and now is not the time you had planned to do it.
Nature doesn't follow our plans though, does she?
keithz
Re: Bummer!!!
Close
Ron in Drums PA
>even worse
Re: Bummer!!!
Saps up
Bob Fawcett
Re: Bummer!!!
chain saw is in the shop
adrien
Re: Bummer!!!
Keith Tompkins
Re: Bummer!!!
Keith Tompkins
>You need a new chainsaw? Leaving on vacation? That's it...need a bigger lathe!
Re: Bummer!!!
Nope
Ron in Drums PA
Re: Bummer!!!
Okay, I'll tell you
Ron in Drums PA
>The trunk is hollow!
Re: Bummer!!!
Re: Okay, I'll tell you
Bob Fawcett
>Bummer.
There must be some good wood somewhere.
Re: Bummer!!!
Jake Niedling
>I guess that means you have less work to do on the lathe. :)
Re: Bummer!!!
Dave Belser
>Thats not a bummer thats an opportunity!
Seriously, some of the most interesting items I've turned have come from rotten trees. If the trunk is hollow it's very likely that there is lots of staining higher up. Hollow branches 6" dia or smaller can be turned into really nice tea lights / lanterns. When the ants leave holes and channels you can get some really amazing pierced edges. It's possible that your tree is just fire wood but give it a second look.
I wish I lived near by.
- Dave
Re: Bummer!!!
>Time to take up spindle turning. I'm sure there's a good Windsor chair in there somewhere.
Re: Bummer!!!
Jim Underwood
>Check out the AAW forums. There's a couple of cool bowls turned from some lightning damaged trees. Sleigh bowls the guys called them.
There may be more opportunity than first meets the eye Ron. Take another look....
Re: Bummer!!!
Prehollowed form!
Phil Joines Krum, Texas
Re: Bummer!!!
Bill Hale / The Wood Spinner
>Turn it as is. You can create a neat hollow form if there is enough to mount. Just turn the outside and hand work the inside.
Good turning and be safe
Bill in Dolores CO.
