Re: Iron & Wood Lily Pads
e
>that's correct, jen...the one on the right is the original turned and carved wood piece.
then a sand mold is made -- it is a two-halved mold made of resins mixed into fine silica sand. it's at least a two-day operation to create both sides. then the two halves are bolted together, a spout and some vents are added, and the iron is poured into it.
once the iron is removed from the mold, there's a lot of clean-up labor--cutting off the spurs and vents, grinding, sandblasting, refining. furthermore, the iron is so bland that it can overwhelm the shape. therefore, the next step is to develop a patina--a chemical reaction with the metal resulting in color and texture.
wood is really an extraordinary substance to work with because of its innate color, texture, grain, malleability. iron, however, is relatively limited to shape and texture, patina or coating. getting a patina on iron, steel and aluminum is especially limiting.
the patina on this piece is an example of a hot patina of bismuth, ferric nitrate, and potassium dichromate built up in layers to develop the range of colors.
hope this clarifies these pieces a bit more.
