THE WOODRAT IS BACK!
Storing green wood
Storing green wood
Storing green wood
Ricco G
>Hi I'm new to turning. I have some green blanks that are coated in wax and some green logs that are end sealed with green wood sealer,how and where should I store them until I'm ready to turn them
Thanks Ricco
Re: Storing green wood
TDaniel
>The logs need to be off the ground in a shady area with good ventilation. Depending on the climate where you are you may need to do more. If you plan to use them soon this should be enough but for long term storage you should cut the logs into blanks and seal them well. You'll lose some no matter what you do. For more info you might tell us what kind of wood it is and where you live.
TD
Ricco G
>Some of the wood is already cut to rounds,walnut,cedar elm, osage org. I have a blk. birch log the ends are sealed,some apple and grapefruit logs that are sealed. I live in SE PENNA outside of Phila.
TDaniel
>Since you are not in an extremely dry area and none of the woods you mentioned are that difficult to store just follow my previous post and you should be ok.
TD
