Buying new lathe
Buying new lathe
Buying new lathe
Ricco G
>I want to get a better lathe than I have, now I have an older Delta 14/11, I had it since 1981. I was looking at Oneway #1224 and 1640 and also Delta1642-16" and Jet 708358. Am I comparing apples to oranges I am not a full time turner, Would the Oneway 1224 suit my needs,I like to turn small items under 8" in dia.Is the 1HP enough?
Re: Buying new lathe
TDaniel
>Personally, I think the One-way 1640 gives you the most flexibility and quality. You can add the outboard attachment at a later date if you have a desire to turn anything more than 16" diameter. Some of the reasons I suggest the One-way are:
Excellent back-up
Excellent resale value
Excellent quality
The best banjo and toolrest on the market
#3MT tailstock
Quality throughout. You get what you pay for with this machine.
TD
Ricco G
>What is the advantage of the headstock being MT#2and the tailstock MT#3 and not both being the same.
advantage
TDaniel
>the #3 has more surface area so when drilling with a large forster you will not have as great a tendency to slip. You can add a #2-#3 adaptor if needed.
Re: advantage
>Terry I know that is written up as an advantage but I've never had a problem with a #2 morse taper slipping once I've inserted it firmly. Since you have to find an adaptor to use all your other #2 morse taper accessories and then have to find a drift punch to remove the #2 from the #2 adaptor It seems like more of a problem to me than an advantage.
Re: advantage
>I meant to say that I agree totally with the rest of your assumptions regarding Oneway. They are a fine company making a fine lathe.
Peter Teubel
>The only "limit" you will run into on the Oneway 1224 is the size of your work. In all other aspects, it will exceed your expectations when compared to any other lathe in its class. You can also turn it into a completly self-contained unit with the EXTREMELY sturdy stand it comes with.
In the stand, I have a vacuum pump and a small air compressor on the bottom shelf. Beside the motor on the top shelf is room for a box of accessories (chuck, spurs, drums, lamps, tool rests, drill, etc) and my tool roll. Attached to the outboard side, I have a hinged platform which I have a grinder attached complete with sharpening jigs. My Festool vac in the background wouldn't fit in the stand, so the lathe doesn't have its own dust collection system (yet).
With the aid of a caster platform, couple of ramps, and an electric winch, this has become my traveling lathe. I am currently designing a system of large retractible wheels operated by air shocks to raise/lower the whole thing effortlessly (and to make it easier for transporting over "rough" terrain...like soft grass at an outdoor show). In addition, I will be making some lexan doors for the stand that will disconnect and attach to the front for a shield.
The picture below is from a demo I did at our local club this past February.
Bill Hale / The Wood Spinner
>I agree with Terry. As you turn on a higher quality you are likley to want to turn more and larger. I would go for more than 1 hp as it may limit what you want to do in the rough out stage.
I have two shops and own a Oneway 2436 and a Vickmark 200. Each are great but the Oneway is a better quality lathe.
Buy the best you want to afford and if it is the Oneway you will never be sorry.
Good turning and be safe
Bill in Dolores, CO.
Re: advantage
bob davis
>i agree with you ,john..bob d
Re: advantage
Ricco G
>THANKS everybody for you info and expertise,as I said I am a beginner at turning,I will look more into the OneWay. Thanks again!!!
