A55 Smoothing Plane
Delta 46-745
Delta 46-745
Delta 46-745
Mike D
>Hoping to get some opinions on the Delta 46-745 16" Steel Bed Lathe.
I have found one that is a factory reconditioned for $999 including shipping.
I am primarily interested in bowl turning. Very much a newbie when it comes to wood turning.
Thanks for your opinions.
Mike
Re: Delta 46-745
leave it be....
TDaniel
>Delta lathes give more problems than any others that I know of. I suggest that you do some more shopping.
TD
Re: Delta 46-745
Re: Delta 46-745
Barbara Gill, Remlik VA
>Look down at the thread "Lathe Woes and Pleas for Help".
Re: Delta 46-745
Re: Delta 46-745
Rick in Colgate, Wi
>I have the 46-745, its 2 years old now. This model does not suffer from the same woes that the 46-700 models are prone to.
My lathe is USA made, I'm going to guess the newer ones are not. Mine has a Baldor VFD, the new ones a Delta VFD and dont know if that is good or bad.
The only problem I've had is breaking the locking handles for the tailstock and tool rest, they are cast metal. I've since fabricated my own that will never break.
You will not find another lathe for $999 with a VFD.
Re: Delta 46-745
Re: Delta 46-745
Kevin Mac Luskie
>I bought one (2001 model year I think) used about 2 years ago with 1/2 dozen tools, for $700 or $750 from a guy in Florida. (I'm in Virginia) Fortunately my In-Laws lived near the guy in Florida, and picked it up, and brought it up when they came to visit.
I've really enjoyed the lathe, and haven't had any problems. As many people do, I added a shelf and put about 400lbs of concrete on it to add weight, as I was able to walk the whole thing with out-of-round blanks.
Re: Delta 46-745
Re: Delta 46-745
Allen Neighbors
>I agree with TD. I began with a Sears 12" Lathe, and almost immediately bent the shaft, trying to turn a bowl. Then I stepped up? to a Grizzly with a swivelling head. Ha! Toolrest breakage, and no speed control changed my perspective. Didn't turn on it for a year before I wished I had bought a bowl lathe (or one that was constructed so you could turn bowls).
Now I'm waiting delivery of a Oneway 1640. If I had it to do all over again, and knew I would be turning mostly bowls and hollow forms, I'd have saved up for the better lathe to start with.
If you don't get one that's heavy duty enough to start with, it will hold you back on your progression as a bowl turner. It did me. JMHO.
Allen
Old Griz is driving me crazy. :o)
Re: Delta 46-745
Re: Delta 46-745
Bob Fawcett
>I don't have a delta lathe and never did. I agree with TD as he usually knows what he is talking about.
Try this:
Woodcraft has a fathers day special on a Jet mini with a Nova Midi chuck for $269. This is a great starter lathe. If you decide you love turning - save your money for a Oneway 1640, a Powermatic 3520B (get the B not the others) or a Vicmarc, or one of the other top quality models.
Re: Delta 46-745
Re: Delta 46-745
John Veerkamp
>see my thread below. I would be leery of the Delta 745 because of the controller/inverter. Delta offers the replacement as on the 755 but it is $800 and comes from China. My controller is the Baldor model 15P series made in USA. I'm going to try Baldor repair service directly to see if they can help. The Lathe has been a very good tool and heavy enough for 15" bowls, but this problem with maybe 350 hours would have made me think twice.
I'm still hoping to get mine repaired and I'll post updates as appropriate.
John
Re: Delta 46-745
Re: Delta 46-745
Fog Tanner
>I have had that lathe for the last four years and only had a few issues with it which were corrected by Delta. I was one of the few people in the country that was coring bowls (McNaugton system) with it. The controller had problems with the load, and Delta sent a brand new one that Baldor had programmed for that. No problems since.
Had I not gotten intertested in offcenter turning, it would still be my only lathe. I was using it for offcenter work, but limited in the final size. I wound up buying a 24" Vicmarc, so I now have two lathes with the Delta being my mini. I liked the steel bed Delta better than the Jets and never regretted buying it. The only regret I have, is not starting out with the Vicmarc, although the Delta let me find out if I really liked woodturning and I wound up with a great "mini"...
