Tried Something New With A Slimline *LINK*
George (Oxford, NC)
>May not be new but at least its a new style for me. I cut the upper blank length to (standard length + thickness of centerband + �"), used a tube that was standard length + thinkness of centerband. Drilled out the �" with a bit the same diameter as the 7mm bushings OD. Turned the lower blank BtoB so the �" hollow in the upper tube would overlap the lower tube. Material is cedar.
George
http://www.ncwoodworker.net/gallery/showimage.php?i=4411&c=197
Re: Tried Something New With A Slimline *LINK*
Jennifer@Indy.USA
>Nice one George! The slim line kits are so fun to mess areound with and change the designs. I like your burned rings on this one too.
Very nice!
Jen
Allen Neighbors
>That's a beautiful pen, George. I love cedar. I also like the burn rings. Your patience amazes me. :o)
Allen
Scott Greaves in Blackfoot Idaho
>Hi George!
Nice modification! I like that cedar!
Now, if you want to have some fun, make the same pen in the same way, only cut about 1/4" off the top barrel, making it shorter. It changes the ratio of top to bottom barrel, will give it a sleeker look, and will overall change the perspective of the pen.
Ain't penturning fun!
Scott.
