Is it dry yet?
Is it dry yet?
Is it dry yet?
Jerry Ingraham
>Being relatively new to turning and without a moisture meter, how do I tell if a blank is dry enough to turn to completion? Some blanks seem dry and maybe that's all there is to it. Any sage advice? Thanks.
Jerry
Re: Is it dry yet?
Re: Is it dry yet?
Rick Allen
>If you Kiss the blank
Dryness becomes apparent
Cool no and warm yes
Re: Is it dry yet?
Re: Is it dry yet?
Jim
>You can weigh it periodically, recording the weight as you go. When it stops losing weight for a week or two, it's reached equilibrium moisture content for the area.
Or you can just wait 6 mos to a year if you've roughed out the blank to 1 inch thick per 10 in diameter. (I think that's right.)
Usually a green log dries one inch per year in its uncut form. So if you've roughed out a 1 inch thick bowl blank it should be dry after 1 year.
Several people speed up drying by using a microwave, or alcohol soaks. I've not tried either one, so can't vouch for either method.
Re: Is it dry yet?
Re: Is it dry yet?
Bill Crommett
>Keep on weighing until the wood stops losing weight.
Re: Is it dry yet?
Re: Is it dry yet?
David Breth
>And by the way, I've found the self-service thing at the post office to be an excellent scale. And the price is just right.
David B.
Re: Is it dry yet?
Re: Is it dry yet?
>I use both methods. You can feel when a blank is dry. It will feel warm to the touch. Large blanks I weight and then check them periodically and record the weight. When they stop losing weight they are dry. Just a ball park,my large bowls that are 16" and probably 1 1/2" thick will dry in 6 months or less here in Tennessee. Smaller bowls 12" that I leave around 1" thick will dry in about 3 months. I don't worry about it anymore, I rough more than I turn so there's always about 10 to 15 laying on the shelf, most are much over 6 months old so I know they are all dry. Now that I have a little more space than my old shop I'm going to try to set up some drying shelves. Freshly turned go on the bottom and I will move them up as time goes by. That way whatever is on the top shelf will be dry enough to use.
Re: Is it dry yet?
Re: Is it dry yet?
Lan Brady
>Jerry,
I would like to give you a response, but I cannot get the thought of Rick kissing bowls out of my head long enough to write a readable response. I hope he does this late a night so that no one sees him.
Rick,
Thanks for making my day a little nicer. Of course, everyone around me now knows that I was not working on company stuff. No problem though, I will gladly work late tonight and enjoy it.
Good luck to all, Lan
Re: Is it dry yet?
Re: If it doesn't sling juice ....
JamieDonaldson
>... while spinning then its dry enough to turn for most purposes. But don't try to glue up any damp wood!
Re: Is it dry yet?
Re: Is it dry yet?
Stephen Mushinski
>I will use my nose to check moisture content in wood. Works very well and if you practice you can even tell about what percentage. For those that think I am kidding, I am not. Put a wet board under your nose and then try a dry board you will sense the difference. Wet will be cold dry will be warm. I say to use your nose as it if much more sensitive then your hands. I have not tried kissing the wood but I am sure it would work very well also. - Steve
