minwax tung oil question
ken chase
>My first use of this product. Should I sand between coats?
Thanks
ken chase
Thanks
Re: minwax tung oil question
Stuart Johnson
>Ken, I use 0000 synthetic steel wool between coats.
RevDoug
>Steel wool will do the trick. Unless you wet sand with the oil, the soft finish of the oil will tend to gum up, or load, the sand paper pretty quickly. You may want to experiment with sanding in the oil. It is a long process, but gives incredable results. Check with Russ or Terry Daniel for details. 8)
Turn 'em round,
keith zimmerman, Normal, IL
>I usually don't do anything between coats, unless there are runs from voids in the surface. I will sand the entire piece with 400 or 600 grit to remove the buildup from around the voids.
Other than that, I haven't seen much benefit to sanding between coats. I buff after 5-6 coats and the tripoly/carnuba wax works well to complete the finish.
I don't wet-sand with Minwax Tung Oil because it does turn into a gooey mess and is very hard to get rid of.
That is my $.02.
keithz
>Ken Years ago I used a finish like that and I would apply the finish with 600 grit paper. I would just do a small section at a time. The slurry would help fill the grain and make a super smooth finish that my customers loved. This way I would be sanding between each coat.
I am currently experimenting with the Minwax wipe on Poly and I have been using 4/0 steel wool between coats.
Carole Valentine
>When using Waterlox, I hit it lightly with 6/0 steel wool cloth between coats. Each coat is wiped almost dry as it is put on so there is not much need to sand.
thanks all for the tung oil advice
ken chase
