Carbide pen mill
Carbide pen mill
Carbide pen mill
Joe Pack
>I do a lot of pen turning, keychains, etc. several hundred a year. I have used a pen mill a bit, but find that they go dull so quickly that they are not worth the trouble. I use a 6" belt sander w/miter fence that works great, assuming the barrel is drilled straight, which, unfortunately, is not always true. Also, I still have to often scrape out excess epoxy from the inside of the barrel. Doing a couple at a time, this is not a problem, but, when doing 100 at a time, cleaning barrels is a pain.
Now, Penn State offers a carbide pen mill set that should square and clean at the same time.
Some questions:
1. Have any of you used a carbide pen mill?
2. If you have used one, what is the "sharp" life compared to steel?
3. If you have not used one, what is your best guess as to "sharp" life compared to steel?
Re: Carbide pen mill
Pete in Holland, MI
>Have no experience in pen making, but carbide will probably outlast HSS 10:1 in wood working. You will need either a green grinding wheel or diamond hone to keep an edge on it.
Stuart Johnson
>I melt some bee's wax and pour it out on a cookie sheet making a very thin sheet. Before gluing the the barrel I use it like a biscuit cutter. The wax prevents the glue from going into the barrel. It then pops right out. I toss the little bits into a jar and remelt from time to time to form a new sheet.
Jim
>In my experience carbide will last longer, but the edge won't get as sharp as HSS. I have a theory that Carbon steel will get sharper than HSS, and HSS will get sharper than Carbide. Something to do with the hardness.
eaglesc
>I touch up my pen mill with a couple of swipes up the vertical face of the"flute".If you look at it , there is a square edge.
Lowes has a small diamond stone with a 90* edge, Goes for about $6.00.
I don't touch the angled face of the cutter.
It seems counterintuitive but works.
After using this method shavings come off the blank rather than dust.
I turner a lot of bone and antler. The results are dramatic.
I really don't want to bother trying a carbide mill.
