Weight
Weight
Weight
Dave Winters, Steamboat Springs, CO
>Anybody use weight, like bird shot or bb's to give some weight to turned items? How to seal it in there, epoxy, wax??
Thanks
Re: Weight
Re: Weight
>My one attempt at this was a pair of candlesticks. I drilled a hole in the middle of the bottoms. I then took part of the cutoffs and used a plug cutter to cut plugs. I put some lead shot in the cavities and pressed the plugs in with a touch of glue on the sides. I suppose steel shot would work. I just happened to have some old lead birdshot.
Re: Weight
Re: Weight
>Dave I've done 2 things. make a groove and pour in a mixture of BB's and epoxy. I mix a little india ink with the epoxy so it's black instead of clear. I also melt lead and pour it into a groove. It sometimes shrinks too much so I add a little epoxy or CA glue after the lead cools to secure it in place so it won't rattle.
Re: Weight
Dick Hines
Re: Weight
Dick Hines
>I did a tall bowl of BLM with an oneven rim. One side was highter that the other. Came down to a small foot. To small that is. Bowl would not sit up. Kept falling over like a drunk.
Lucky for me the foot was deep. I drilled out the foot and put 4 finder washers inside. Used CA glue to keep them in one place and turned a plug. Next show it was the first piece I sold.
