Sioux Drill
Sioux Drill
Sioux Drill
Jim Dickman
>Good Morning.
I'm considering buying a Sioux close quarter drill for sanding my bowls. It gets good reviews. Any feedback or info I can get is greatly appreciated.
Re: Sioux Drill
Re: Sioux Drill
Darryl Hansen
>Jim do a search for Souix or Milwaukee close quarter drills. Main complaint is that the rear bearings are not sealed nor covered in grease as are the front set. If you blow them out periodically the drill will last a long time. I have used one for four years with no bearing replacement although it is probably just a matter of time. You can usually get a Milwaukee/Souix (same drill different color) on ebay for around $65.00 or so. The knock offs also on ebay $30. You can tell the difference since the knock offs have a small rubber tab on the cord near the handle. They could be considered throw aways but they also do a good job. Having used both types I would not spend the $150 or so for a Souix wihtout trying ebay first. Whatever you get they make sanding much much easier....
Re: Sioux Drill
Sioux Drill
Jim Dickman
>Thank you so much. I will check out e-bay!
Re: Sioux Drill
Re: Sioux Drill
Dave Belser
>Sioux has a high speed and a low speed version. Get the low speed one. I have one and never even approach it's max speed. Also consider getting a trigger block/wedge/support thingy from Craft Supiles USA. It's a little hunk of plastic that you strap under the trigger and it makes partially depressing the trigger much less stressful on your finger. You could probably make one from a bit of wood, but it was real cheap and I was buying the drill from them anyway.
Bearings seem to be a problem for some more than others. I have yet to blow the dust off of mine and have not had any problems yet. Maybe I'll start blowing the dust off.
- Dave
Re: Sioux Drill
Re: Sioux Drill
Russell L. Babbitt Jr.
>After reading a lot about bearing failures I recently took mine apart and oiled and grease it. It may not make a difference but it makes me feel better about it lasting longer. I also second the idea of getting the low speed version. It is more than adequate for sanding on the lathe.
Re: Sioux Drill
Re: Sioux Drill - A different Viiew
>I, on the other hand, have the high speed (2,500 rpm) Sioux, which does beautifully. I spin the wood at less than 80 rpm, crank the drill up high, and just barely kiss the wood. This keeps the abrasives cool and allows me to work through the grits in short order. You won't find one cheap or KO'd, however. Mine's been running strong for 4 years.
Re: Sioux Drill
Re: Sioux Drill
PAUL FOWLER
>Methinks the 2500 RPM model MAY BE 1/4" capacity, limiting usfulness around the shop.
Re: Sioux Drill
Not
>It has a 3/8" keyed chuck. |;-}}
Re: Sioux Drill
Re: Sioux Drill
>http://www.woodturnerscatalog.com/cgi-bin/shopper
Re: Sioux Drill
Re: Sioux Drill
>Link does not work.
Craft Supply shows a high speed and low speed with 3/8 capacity.
Re: Sioux Drill
Save $25 *LINK*
>On either version at Packard.
Packard-Sioux
Re: Sioux Drill
Re: Save $25
robo hippy
>I picked up a pneumatic Sioux angle drill from Woodworkers Supply several years ago. Seems like it was $300 or so. I am now in the process of seeing how long it takes me to wear it out.
robo hippy
Re: Sioux Drill
Re: Sioux Drill
Bill Crommett
>If you need a trigger lock, save money and just put a finger under the trigger.
Re: Sioux Drill
Brian McKearney
Re: Sioux Drill *LINK*
Brian McKearney
>I have the 8800ES and I like it a lot. For a decent price, check out Coastal Tool. I bought mine from them and they were good to do business with and shipped it to me promptly.
Brian
Coastal Tool - Sious Power Tools
Re: Sioux Drill
Re: Sioux Drill
>The 8000ES and 8800ES are two different drills. I suppose that's a Duh!, but I have not seen the 8800 before. Wonder if it would work as well and if it has the Bearing's "problems"?
Re: Sioux Drill
Brian McKearney
Re: Sioux Drill
Brian McKearney
>They are two different drills, but I liked the looks of the 8800ES better myself - I saw the two in either Packard's catalog or Woodturner's Catalog (can't remember which, but one of them carries both drills). So far, the 8800ES is holding up well for me, although it at times seems like it is getting a bit louder, which has me a bit concerned that it may suffer from the same problems as the other model. I would assume that the internals of the two drills are very similar, so I wouldn't be surprised if both suffer from the same problems.
Re: Sioux Drill
Re: Sioux Drill
Dennis Taylor
>I have 2 Sioux Drills, 3/8 both are used but in great working order, I have pictures and willing to sell for 65.00 each, ...sorry if this isn't allowed, just read the post and have 2 to offer for sale...Dennis
