? About "Burl" Effect in Cherry
RevDoug
>I was given two logs of cherry that have all kind of "burl" type of graining. The effect goes completely through the log and from what I was told about it is that the entire trunk of the tree is/was like that. On both chunks that was given to me I noticed what looks like char on the bark.
Is it possible that the "burling" was caused by a lightning strike that only grazed the outside of the tree?
Turn 'em round,
Re: ? About "Burl" Effect in Cherry
Brad Vietje
Brad Vietje
>No idea about the lightning part, Rev, but I've seen quite a few Black Cherry trees with all sorts of healing growths from injury. The figured wood looks a lot like burl wood, and most people would call it such.
There are all sorts of things that cause this sort of growth -- sort of a scab on the tree -- from another trunk rubbing against it, a branch broken off, repeated scrapes from a snowplow, or other insults. The outside looks black, like a burn. Maybe an actual burn, from lightning causes a similar burl response ?
There seem to be more than one sort of "burl" to begin with. Some are healing growths around injuries, some mere thickening of the growth rings (common in Maples), and then the full-bore "eye" burl of dormant buds, so common in Boxelder and BL Maple. Which are true burls, I'm not qualified to say -- but all look nice, and I'm glad you found some to turn.
Safe spinning,
Brad Vietje
Newbury, VT
Bill Crommett
>Can you explain what causes "Birds-eye" ? I have even seen it in Oak .
