glasslike finish
glasslike finish
glasslike finish
eliot
>I recently saw a finish on a turned vessel that looked exactly like colored glass. I don't mean that it was just extremely smooth, although it was, I mean that glass craft people were fooled by it; they thought it was glass. Also, the wood grain still showed through the finish. Does anyone have any suggestions on how to go about getting such a finish?
Re: glasslike finish
>Eliot I do 3 finishes that are like that. I do shellac and lacquer. I build up many layers until the pores are filled then sand and buff until it's perfectly smooth. This takes a fair amount of work and the lacquer seems to work better for me if I spray it, in fact the shellac works better sprayed also.
I have been experimenting on using Berchwood/Casey tru-oil for turnings. I had to refinish a rifle for a friend and purchased some of the tru-oil. I had forgotten how fool proof this stuff is. You put on a layer of finish and let it dry. Then steel wood it down until all you see shiny is the pores in the wood. You keep doing this until you no longer see the pores as shiny spots but the whole object is evenly dull. Then apply 2 more layers. Steel wool between them but leave the last layer to dry. Sometimes you have to steel wool this layer and buff it to a gloss, sometimes it will dry quite even and glossy on it's own. I guess it has to do with humidity and heat so the chemicals that make it self leveling have time to work. It takes about 6 to 10 coats to do the job but takes very little time to do each coat. I let it dry overnight and hit it first thing when I go in the shop so it has time to harden before I start creating a lot of dust.
I had a piece laying out this weekend with 6 coats. It wasn't quite level and glass looking but everyone who came in the shop picked it up and commented on how good it looks. It had some minor flow lines that will be quite easy to flatten with the steel wool.
Bob Fawcett
>eliot,
In my limited experience, Mark Kauder is the master of this type finish.
http://www.markkauder.com/index.html
His finishes are many coats of laquer sprayed on until there is sufficient build to mirror polish. He uses micro abrasives and wet sands by hand until he has an optically clear or nearly so finish. Some are polished to 1 micron abrasive.
The color is tinted laquer similar to "candy apple" automotive finish.
I am sure Mark will be happy to give you additional information when he is ready, but please don't bother him right now.
http://www.woodcentral.com/cgi-bin/turning.pl?noframes;read=111277
Sean Troy
>After you've finished your high gloss finish. You can apply a product from 3M called Finesse It. It's a liquid polish that you rub on and buff off. It gives that little added extra gloss.
David Galloway
>I too have been seeking that glossy shine and agree that Mark Kauder is one of the best. Another master is Russ Fairfield who has produced a superb 3 disc video that tells and shows you how to do it. It is well done and is worth the time and money to let him show you his "secrets". You can go to his finishing secrets her on WC and can find links to his website. He processed my order with great speed.
David
James McClure
>That sounds like Don Derry's work.
http://www.donaldderry.com/
Re: glasslike finish *LINK*
Carole Valentine
>Take a look here.
Don Derry
Keith Tompkins
Keith Tompkins
>A few hints on finishing...your final finish will only be as good as the wood preparation beneath the finish. If you want a perfect finish, the surface of the vessel must be perfect as well. Scratches, torn grain, etc, will telegraph through, and as the finish settles, it will get worse.
When I am satisfied with my prep, I lightly dampen the surface of the vessel, then allow to dry thoroughly. Then, resand in stages to 600 grit or finer. Lacquer is good for this type of finish, expect to spend as much time on the finish,or more, than the vessel took to make. Apply at least ten coats, I use twenty on showpieces. Each coat must be sanded until no shiny spots exist, then the next coat. I sand by hand,after building a good film, using water and detergent and automotive wet or dry paper..down to 2500 grit on the final coats. I buff by hand with fine auto compound...machine buffing will easily cut through several layers..if that happens, you may as well start over. Don Derry uses an optical quality clear lacquer finish...
eliot
>Thank you all. It's very interesting that several of you mentioned Don Derry. As a matter of fact, it is exactly Don't work that I had seen, and , in fact, I met him and talked with him just this last Saturday for several hours and bought one of his vessels. Don is extremely generous with information about nearly everything he does. But when it comes to his finishes, he says that his process is extremely complex and time consuming and would probably require a book to explain it properly. So I let it go at that -- except I still figured that I could research the issue and perhaps get something close to what he does. So thanks again for your suggestion; I will try some of them and report back. By the way, in the spirit of giving something back to the group, I can tell you that Don is a big proponent of shear scraping with a scraper that is not simply ground to produce a burr, but is further developed by polishing off the burr and then burnished with something like the Veratas burnishing tool.
>Keith I hope I have time to do this test before my next club meeting but I've always wanted to do a test of how sanding affects the final finish on a really thick finish like were talking about. I plan to sand a board to 220, 320, 600, etc up to a really fine gloss and then apply a high build finish over each section. It will be interesting to see the difference in the final result. I may do it on boards I can cut up afterword so I can pass them around and see if anyone can tell which is which.
Keith Tompkins
Keith Tompkins
>Let me know your results, John. I think you will be surprised at the difference!
Russ Fairfield
>John,
I think you will find that the smoother and more polished the wood under the finish the more "depth" you will see in the finish. That is because there are now 2 smooth reflective surfaces - one on the top of the lacquer film and the other one on the bottom of the film. That slight difference in the angles of the reflected light gives the illusion of depth, and the better the bottom surface can reflect the light the deeper the depth.
The clarity of a lacquer allows for this to happen better than any other finish.
>Thanks Russ and Keith. I'm going to do it with both Lacquer and Tru-oil. I don't have any good shellac right now so I won't do it with that. What wood should I use for the test? I would like to do 2 different species. I don't have anything really fancy right now. Mahagony, walnut, maple, cherry, purple heart, Hickory,Holly, yellow heart. Not sure if I have any birdseye maple but can get some curly maple at my local store.
