Tip for newbies
Tip for newbies
Tip for newbies
Carole Valentine
>Intended to post this a long time ago when I was asked how I reversed chucked hollow forms, but never got around to it. When I was first starting hollow forms I often had problems with them spinning as I tried to finish off the bottom after reverse chucking them. This is my method now and I never have a problem. The material is the rubber drawer liner/router mat stuff. I got an 8' roll of it at Sears I think. Just cut an appropriately sized square, cut a small X in the center and slip it over the cone. Guaranteed to eliminate slippage.
Re: Tip for newbies
Re: Tip for newbies
Jake Niedling
>Carole - Great post with pictures. I am just as guilty for not thinking to pass along some of the simple things that work for us. To most a picture is worth alot.
Re: Tip for newbies
Re: Tip for newbies
Allen Neighbors
>Thanks for posting this, Carole. I've been using foamies from Wal-mart, and they still slip. Going to get the drawer stuff for the next one. Good pics, too, like Jake said.
Allen
Re: Tip for newbies
Re: Tip for newbies
Jennifer@Indy.USA
>Carole I use this stuff all the time too, but being the "thrifty" or cheapie...which ever you want to call it .....I buy mine at Wal-Mart in the kitchen doo-dad isle. It's a ton cheeper than the router mat stuff and it's the exact same stuff. Just as thick. They have thin or thick...and it comes in designer colors too!
Jen
Re: Tip for newbies
Re: Tip for newbies
Carole Valentine
>Thanks,Jen. I looked at W'Mart and all they had at the one nearest me was the shelf liner that was thinner and not as rubbery as the mat I got at Sears. Maybe they were just out of stock on the thicker stuff...have to ask them. But then again an 8' roll of the stuff I have should last a while! ;)
Re: Tip for newbies
Re: Tip for newbies
Allen Neighbors
>"...and it comes in designer colors too!..."
Hey, Jen. Boy! That's gotta be a girl thing... Do you use different colors for different types of wood? :o) Just kidding...(jab to the ribs, wink, wink, smile)
Seriously, I've used it as sanding mat before, and you just throw it in the washer when it get's where it doesn't hold, and it's restored!! I just never thought about it for the jam chuck use..
When are you going to post some more pics of your pieces?
Allen
Re: Tip for newbies
Re: Tip for newbies
Bill Nichols
>This newbie says thanks! I was having trouble holding something I was experimenting with last week and have a roll of that stuff sitting on my work bench collecting dust. I'll put it to work next time. Thanks!
Re: Tip for newbies
Re: Tip for newbies
Jim Shaver Oakville, Ont.
>Hi Carole,
Thanks for posting this. I am saving these images for my file of "WHAT TO DO" when I make one of these forms again.
take care,
Jim
Re: Tip for newbies
Re: Tip for newbies
>Carole, I have been using really cheap carpet pad. Most of it is pink, made of one type of foam, not the stuff made of crumbles.
Also, I use "Dickie the Stick" (reference to an old Johny Carson routine)on deeper hollow forms. I made a stick with a number two taper and a shoulder on it and its about the diameter of the hole in the form and 8" long. There is a little dimple centered in the end. I leave a little nib in the bottom of the form and drop in a piece of carpet pad. I also try to leave the live center mark in the bottom of the blank for the HF. When I reverse chuck, all I have to do is remove the chuck from the lathe, install Dickie in the shaft, slide the HF over it and then bring up the tail stock. This way, I am not compressing the walls or top of the form itself, but just pressing directly through the bottom against the stick. If the stick is too slender, I wrap some tape around it at the mouth of the form to center it up. If it really too slender, I wrap some foam around the stick and tape it. I started doing this because I crushed the top of a sort of short fat HF. Those end grain fibers in the top and bottom are really short and weak if you cut them thin. The business with the nib and the hole in the end of the stick started as a way to center it, but may be more about being too lazy to carefully remove the nib and justifying leaving it. Works fine without it if you can center the form.
Re: Tip for newbies
Re: Tip for newbies
Carole Valentine
>Hi Barry,
I find that it takes very little pressure to hold the piece using that tacky mat. Have never had one crack (famous last words!) Just think - all the trouble I go to to remove the nub and have the bottom of the inside baby-butt smooth and you come up with a valid reason to intentionally form a nub! LOL
