Basket weave closed form
Jens Bingel
>I would like to test my patience and turn/carve a basket following J.Paul Fennell's tutorial. My question is if a reciprocating carving kit for my Dremel is adequate and if so what bit to buy and where to square the little holes. J. Paul Fennell mentioned a bit No. 165L in a dental catalog, but I have not found the catalog.
Any advice will be greatly appreciated.
Jens
Re: Basket weave closed form
>I haven't looked at J Paul Fennels tutorial but I believe he uses a high speed carver. You can to it with a dremel but you have to go really slow and take light cuts. The Dremel wants to pull into the wood and follow the grain unless you control it very carefully. It only runs at 36,000 rpm. The high speed air grinders run at 400,000 rpm and they almost melt the wood. Some of his vessels are thicker and he may be using other powered carvers, I don't know, I'm just guessing based on my own experience. When I have pierced vessels thicker than a couple of sixteenths it's very slow and tedious with the Dremel.
Richard Allen
Richard Allen
>Why not ask J Paul?
Jens Bingel
>I like to thank you, John and Richard, for your kindness in taking the time to respond to my question. The answers were straight forward and to the point. I guess I will contact J. Paul.
Thanks again,
Jens
