We value your privacy.
>I have used the Kelton mini hollower set (5/16 x 8) of hollowing tools to hollow small forms (ornaments; etc). Can the 1/2 in or 5/8 set be used reasonably easy without getting into the armbrace or captive systems? I know the type of wood and final shape are factors but I want to talk in general terms. I'd like to try some larger hollow forms but do not have a feel for what size for can be turned before the job becomes a chore instead of fun.
>Tom- I'm a fan of John Jordan's hollowing tools in the Stewart/Sorby armbrace handle. The control and feel are superior to all other tools, and for the largest hollowing jobs that require a boring bar set-up I still make the final thinning cuts with a teardrop scraper blade in the Stewart handle for best best control.
>I just had a custom boring bar made for my Kelton hf blades. I have the whole set. I tried to do it free hand, and while it does work, it was a work out. The D handle, tool rest, and handle rest does a better job of keeping the bar level, and at exact center. The boring bar is 1 1/2 inch pipe, with a 10 inch piece of 1 1/2 DOM (with a 3/4 inch bore, that was reamed out to 13/16) welded on. I figure that I can reach out 15 or more inches with ease. I have done 10 inches, but to go much farther, I need a steady rest. I can slide the blades in as far as I want, and the adapters fit. Also, a laser pointer is a bit top heavy if you just have it on the KM handles. You can use the hf cutters to drill out the bottom, but use the straighter bar, and the cutter has to be dead center. I was using a more curved bar last night, and the curved part bounced off the nipple in the center, then slammed down, and caught.Three pieces of maple burl firewood.
I use the 1/2" Keltons in an Exocet handle all the time. Works great. I just wish they were 2" longer. The shapes are great. I also have the 1/2" Jordan tool. Very good also, but more limited in the shapes you can do.
>You must only have one Jordan tool. With one straight and one curved I can do just about any shape imaginable. Your limited in the size with 1/2" bars. If remember correctly about 8" is as deep as I can go without getting too much chatter. I switch to 3/4" bars for deeper pieces. I don't own the Jordan tools, I built my own but I do have his Shear scraper and it's excellent. I want one of his curved tools becasue it's built better than mine.
>I've been using my Stewart too since 1988. I've tried a few others but have found none that I like better. The swivel tip makes the difference. The ability to swivel the cutter so that it's presented to the wood in the best possible way for cutting as I work my way from the top to the bottom of the piece gives the Stewart type tool an advantage over all others in my opinion.
