Al-C or Duane
RevDoug
>What is the name of the manufac. for the 2 prong drive center for the chuck? I'm seeing them at retail but you guys had mentioned getting them from the company. Thought I'd go that route.
Al-C or Duane
RevDoug
Re: Al-C or Duane *LINK*
Bruce Wiseman
>Hi,
Obviously, I am not Duane or Al but I think you are looking for the drive insert from BestWoods Tools. I got mine from Packard but they later told me that they got it from Bestwoods. Mine looks just like the one I've seen Duane use.
Regards,
Bruce
http://www.bestwoodtools.com/
Oneway make one also.
Dennis Y
Re: Al-C or Duane
David Propst, Valdese, NC
>Hey Rev Doug!
You'll get it from Packard more quickly at the same price.
Take care,
David
Re: Like Bruce said, Best Wood Tools.
Al Crandall (NE of Indy)
>Hi Rev. It was nice to put a face to the name at TD's. I enjoyed our brief conversations. Duane uses a 2" two prong drive for a Vicmark chuck and I use the same size for my Talons. Check them out at:
http://www.store.yahoo.com/bestwoodtools/2flutquiccha.html
Oneway doesn't make a chuck based drive this large that I can find on their website. I like it because it never looses it's grip like a smaller 4 prong drive does when supporting a heavy chunk. BWT touts the ease of changing from spur drive to chuck, but they really should push the safety factor of having a large spur engaged in the heavy green wood. One piece of advice I'd like to pass along when using large drives is to lock the spindle and GENTLY rock the wood back and forth while tightening the tailstock handle to deeply seat the two drive prongs into the wood fibers or the bark. Once properly seated the drive won't "drill" or spin and loose it's grip like a smaller center will. I usually try to align the two prongs with the grain so they will seat deeper and easier. Don't forget to occasionally check the tailstock pressure while roughing. I can't speak to the speed of service being better from one supplier than another. I don't recall the shipping time for my drive being excessive.
Order direct
Gary Evans Tallassee, TN
>Hi Doug,
While you can get the BestWood Tools from various suppliers, I would recommend ordering directly from the source. I've met Victor and his wife at numerous symposia and know that they are just regular folks trying to make a buck.
If you order from Packard et.al., BestWood only gets a wholesale price for the item. Much better for them if you order directly. It might take a day or two longer because they spend so much of their time serving the turning public directly at the symposia, but life's too short to get in so much of a hurry.
My 2cents,
Gary
Thanks All!
RevDoug
