need help w/hollow form
dwfII
>I have a big leaf maple hollow form I'm just now bringing to final shape. I want to put a ebonized persimmon "spout/nozzle" on it...not too high--half inch or so. I have some squares of 1 inch thick by 4 by 4 persimmon but am still uncertain as to how to mount the squares on the lathe given that I will need to drill a one inch hole through the middle of the spout...sooner or later. I wonder if this is even do-able given the thickness/thinness of the persimmon? Should I start with something thicker, turn a tenon and chuck it up?
Also what's the process? Turn the HF, finish, and then turn the spout, finish and glue the two together? Or should the spout be glued on before finishing the piece as a whole?
thanks
DW
In the High Desert of Central Oregon
Re: need help w/hollow form
Steven Antonucci
steve antonucci
>most of my "spouts" are turned to get a small tenon. I fit the tenon to the opening in the vessel. Once that's done, I grip it in a chuck, where I can shape it, and drill out the center. When it's done, I CA them in place.
Steve
Wally Dickerman in Arizona
>Hey DW, where've you been? You haven't posted in quite a while.
If you belong to WoW, I have a turorial on doing collars, complete with pics. Just go to Reviews and do a search on Collar.
Wally
dwfII
>Thanks Steve.
Wally,
Well I'm still here--read and admire several times a day. Never did get my Vicmarc 200 shortbed (Where would I put it? Where would I sleep once my wife found out?)
I didn't turn much this winter...went to Mexico, instead--Cancun. That plus the fact that I just don't have enough dust collection capacity--all I have is one of those little five foot cannister type from Penn State--I can't handle the dust too much. Same reason I didn't turn much this spring--I was coughing a little too much from pollen to want to aggravate it.
I did finish a big--7"(just about at the max for my little Jet midi)--black locust bowl for my wife. I had this bugger come off the chuck and it tore the foot but I cole chucked it and managed to save it, by carving the second foot rim into seperate "legs." And beautifully figured poplar(?)...some soft hardwood...bowl for my brother for Christmas. Still colloecting wood---there's been a lot of Siberian elm being taken down in my neighborhood...six on this one block alone. I haven't turned anything from it but it's remarkably stable and looks like it might be quite attractive even if (as some have suggested) it stinks.
Unfortunately (or fortunately) I got a new computer this winter and if I belonged to WOW (I think that's the one you so graciously recommened to me) I lost the site and the passwords...everything...in the switch from Win98 to Win XP.
Your recent work has been so fine. I take inspiration everytime I see one of your pieces...just got a burner, for example. If you had an alternate way to access that tutorial, I would be interested.
DW
Invite to WoW....
>DW, I'll send you an invitation to WoW...lots of good stuff going on there.
Wally
Re: Invite to WoW....
dwfII
>Thanks Wally.
DW
